Nextcloud version: 20.0.11.1
Operating system and version: CentOS 7
Apache or nginx version: Apache/2.4.6
PHP version: 7.3.29
Update from v19 → v20.0.11.1 = fine.
Did all DB updates listed in the settings.
One warning left which I ignored: “Enabling MySQL 4-byte support”
Update :mariadb-server-5.5.68-1.el7.x86_64 → MariaDB-server-10.6.3-1.el7.centos.x86_64
Update from v20.0.11.1 → 21.0.3
On line:
Repair info: Change row format for oc_comments_read_markers …
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1025 Error on rename of ‘./nextcloud/oc_comments_read_markers’ to ‘./nextcloud/#sql-backup-54a-2d7’ (errno: 168 “Unknown (generic) error from engine”)
Any ideas on how to get things working again. I tried the fix for “Enabling MySQL 4-byte support” with the cmd in MariaDB “show variables like ‘innodb_file_format’;” on the MySQL db but I get “Empty set (0.002 sec)”…
I don’t know if the two issues are related or not.
I do have a backup of the database from v20.0.11.1.
Any ideas on how to proceed best, don’t want to make things worse…
THX!
'instanceid' => 'oc7x159cmspg',
'passwordsalt' => 'DXoS3hNqrk8qY+xccwccxccwcwcx',
'secret' => 'wcwxcwxcwwxcxw/aQBxSxmPyUay+wcxwcwxcxwcxw/',
0 => 'xcxxcxc.ddns.net',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '20.0.11.1',
'overwrite.cli.url' => 'http://192.168.1.50/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'kareldc',
'dbpassword' => 'sdfdsfdgdsfhsdgfs',
'theme' => '',
'loglevel' => 0,
'redis' =>
'host' => 'localhost',
'port' => 6379,
'timeout' => 3,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\MP3',
6 => 'OC\\Preview\\TXT',
7 => 'OC\\Preview\\MarkDown',
8 => 'OC\\Preview\\MSOffice2003',
9 => 'OC\\Preview\\MSOffice2007',
10 => 'OC\\Preview\\MSOfficeDoc',
11 => 'OC\\Preview\\OpenDocument',
12 => 'OC\\Preview\\PDF',
13 => 'OC\\Preview\\TIFF',
14 => 'OC\\Preview\\PSD',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'dgdffdgfd.com',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.spinternet.be',
'mail_smtpname' => 'nextcloud@mailbox.ddgfgfdgdfgdf.com',
'mail_smtppassword' => 'fdqfsq-fsgg',
'mail_smtpport' => '587',
'has_rebuilt_cache' => true,
'updater.secret' => '$2y$10$sdsfgddfgfdgfgfgfdgfgdf.ucDTca0mMvw3fRiC',
[Sun Jul 04 03:40:27.402377 2021] [lbmethod_heartbeat:notice] [pid 1260] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 04 03:40:27.406981 2021] [ssl:warn] [pid 1260] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
PHP Warning: Module 'apcu' already loaded in Unknown on line 0
[Sun Jul 04 03:40:27.488424 2021] [mpm_prefork:notice] [pid 1260] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.28 configured -- resuming normal operations
[Sun Jul 04 03:40:27.488440 2021] [core:notice] [pid 1260] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jul 04 10:30:57.244497 2021] [access_compat:error] [pid 25098] [client 192.168.1.1:49826] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Sun Jul 04 10:31:26.783973 2021] [access_compat:error] [pid 18201] [client 205.185.120.237:45136] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Sun Jul 04 12:46:17.565103 2021] [access_compat:error] [pid 7864] [client 192.168.1.1:51976] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Sun Jul 04 13:45:35.201897 2021] [php7:error] [pid 15383] [client 139.180.187.233:43588] script '/var/www/html/nextcloud/adminer.php' not found or unable to stat
[Sun Jul 04 19:54:45.823204 2021] [access_compat:error] [pid 18201] [client 192.168.1.1:53372] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Sun Jul 04 20:53:14.315904 2021] [mpm_prefork:notice] [pid 1260] AH00171: Graceful restart requested, doing restart
AH00558: httpd: Could not reliably determine the server's fully qualified domain name, using localhost.localdomain. Set the 'ServerName' directive globally to suppress this message
[Sun Jul 04 20:53:14.422924 2021] [lbmethod_heartbeat:notice] [pid 1260] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 04 20:53:14.424259 2021] [ssl:warn] [pid 1260] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Jul 04 20:53:14.497538 2021] [mpm_prefork:notice] [pid 1260] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.28 configured -- resuming normal operations
[Sun Jul 04 20:53:14.497555 2021] [core:notice] [pid 1260] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jul 04 20:53:18.930358 2021] [mpm_prefork:notice] [pid 1260] AH00171: Graceful restart requested, doing restart
[Sun Jul 04 20:53:18.989954 2021] [lbmethod_heartbeat:notice] [pid 1260] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 04 20:53:18.991190 2021] [ssl:warn] [pid 1260] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Jul 04 20:53:19.066183 2021] [mpm_prefork:notice] [pid 1260] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.28 configured -- resuming normal operations
[Sun Jul 04 20:53:19.066202 2021] [core:notice] [pid 1260] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jul 04 20:53:21.444634 2021] [mpm_prefork:notice] [pid 1260] AH00171: Graceful restart requested, doing restart
[Sun Jul 04 20:53:21.509345 2021] [lbmethod_heartbeat:notice] [pid 1260] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 04 20:53:21.510410 2021] [ssl:warn] [pid 1260] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Jul 04 20:53:21.587963 2021] [mpm_prefork:notice] [pid 1260] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.28 configured -- resuming normal operations
[Sun Jul 04 20:53:21.587986 2021] [core:notice] [pid 1260] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jul 04 20:53:21.611669 2021] [mpm_prefork:notice] [pid 1260] AH00171: Graceful restart requested, doing restart
[Sun Jul 04 20:53:21.678281 2021] [lbmethod_heartbeat:notice] [pid 1260] AH02282: No slotmem from mod_heartmonitor
[Sun Jul 04 20:53:21.679365 2021] [ssl:warn] [pid 1260] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Jul 04 20:53:21.763073 2021] [mpm_prefork:notice] [pid 1260] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.3.28 configured -- resuming normal operations
[Sun Jul 04 20:53:21.763089 2021] [core:notice] [pid 1260] AH00094: Command line: '/usr/sbin/httpd -D FOREGROUND'
[Sun Jul 04 21:34:52.496887 2021] [access_compat:error] [pid 3765] [client 209.141.47.35:45434] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Mon Jul 05 08:30:47.844372 2021] [access_compat:error] [pid 22509] [client 209.141.47.35:38550] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Mon Jul 05 13:44:40.557365 2021] [access_compat:error] [pid 5656] [client 192.168.1.1:49814] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Mon Jul 05 17:01:49.750759 2021] [access_compat:error] [pid 31936] [client 209.141.47.35:46572] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Mon Jul 05 18:32:38.804826 2021] [access_compat:error] [pid 31934] [client 192.168.1.1:55191] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Mon Jul 05 20:01:53.218302 2021] [access_compat:error] [pid 31936] [client 192.168.1.1:49819] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Mon Jul 05 22:23:23.907863 2021] [access_compat:error] [pid 21175] [client 205.185.120.237:55654] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Tue Jul 06 02:44:17.010780 2021] [ssl:error] [pid 22621] AH02032: Hostname 109.136.219.154:443 provided via SNI and hostname 109.136.219.154 provided via HTTP are different
[Tue Jul 06 04:26:34.795633 2021] [autoindex:error] [pid 23291] [client 92.196.97.116:53914] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/accessibility/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/accessibility
[Tue Jul 06 04:26:47.097168 2021] [autoindex:error] [pid 23340] [client 92.196.97.116:54358] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/bruteforcesettings/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/bruteforcesettings
[Tue Jul 06 04:26:54.778785 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:54476] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/calendar/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/calendar
[Tue Jul 06 04:26:59.212946 2021] [autoindex:error] [pid 23338] [client 92.196.97.116:54728] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/camerarawpreviews/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/camerarawpreviews
[Tue Jul 06 04:27:05.843513 2021] [autoindex:error] [pid 4089] [client 92.196.97.116:54884] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/cloud_federation_api/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/cloud_federation_api
[Tue Jul 06 04:27:08.437603 2021] [autoindex:error] [pid 4512] [client 92.196.97.116:55124] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/contacts/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/contacts
[Tue Jul 06 04:27:16.079481 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:55352] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/contactsinteraction/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/contactsinteraction
[Tue Jul 06 04:27:21.038643 2021] [autoindex:error] [pid 4511] [client 92.196.97.116:55542] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/cospend/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/cospend
[Tue Jul 06 04:27:28.401914 2021] [autoindex:error] [pid 4089] [client 92.196.97.116:55796] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/dav/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/dav
[Tue Jul 06 04:28:45.338230 2021] [autoindex:error] [pid 23340] [client 92.196.97.116:58644] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/event_update_notification/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/event_update_notification
[Tue Jul 06 04:28:52.965925 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:58858] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/federatedfilesharing/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/federatedfilesharing
[Tue Jul 06 04:28:54.867013 2021] [autoindex:error] [pid 4511] [client 92.196.97.116:59010] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/federation/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/federation
[Tue Jul 06 04:28:57.967223 2021] [autoindex:error] [pid 5051] [client 92.196.97.116:59112] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files
[Tue Jul 06 04:29:08.786047 2021] [autoindex:error] [pid 4512] [client 92.196.97.116:59504] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_external/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_external
[Tue Jul 06 04:29:15.273551 2021] [autoindex:error] [pid 22620] [client 92.196.97.116:59808] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_fulltextsearch/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_fulltextsearch
[Tue Jul 06 04:29:18.608025 2021] [autoindex:error] [pid 28757] [client 92.196.97.116:59886] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_fulltextsearch_tesseract/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_fulltextsearch_tesseract
[Tue Jul 06 04:29:21.817972 2021] [autoindex:error] [pid 23338] [client 92.196.97.116:60006] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_pdfviewer/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_pdfviewer
[Tue Jul 06 04:29:28.213153 2021] [autoindex:error] [pid 4089] [client 92.196.97.116:60204] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_rightclick/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_rightclick
[Tue Jul 06 04:29:32.139666 2021] [autoindex:error] [pid 23340] [client 92.196.97.116:60318] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_sharing/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_sharing
[Tue Jul 06 04:29:45.146886 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:60478] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_trackdownloads/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_trackdownloads
[Tue Jul 06 04:29:54.542578 2021] [autoindex:error] [pid 4511] [client 92.196.97.116:32768] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_trashbin/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_trashbin
[Tue Jul 06 04:29:59.409269 2021] [autoindex:error] [pid 5051] [client 92.196.97.116:32844] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_versions/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_versions
[Tue Jul 06 04:30:18.417880 2021] [autoindex:error] [pid 23291] [client 92.196.97.116:33246] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/files_videoplayer/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/files_videoplayer
[Tue Jul 06 04:30:28.594985 2021] [autoindex:error] [pid 22620] [client 92.196.97.116:34060] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/firstrunwizard/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/firstrunwizard
[Tue Jul 06 04:30:34.001554 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:34238] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/logreader/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/logreader
[Tue Jul 06 04:30:46.925251 2021] [autoindex:error] [pid 23338] [client 92.196.97.116:34756] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/lookup_server_connector/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/lookup_server_connector
[Tue Jul 06 04:30:52.752489 2021] [autoindex:error] [pid 4089] [client 92.196.97.116:34956] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/nextcloud_announcements/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/nextcloud_announcements
[Tue Jul 06 04:31:00.457816 2021] [autoindex:error] [pid 23340] [client 92.196.97.116:35208] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/notes/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/notes
[Tue Jul 06 04:31:19.291868 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:35952] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/notifications/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/notifications
[Tue Jul 06 04:31:22.512667 2021] [autoindex:error] [pid 4511] [client 92.196.97.116:36206] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/oauth2/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/oauth2
[Tue Jul 06 04:31:27.607776 2021] [autoindex:error] [pid 5051] [client 92.196.97.116:36462] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/password_policy/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/password_policy
[Tue Jul 06 04:31:32.785143 2021] [autoindex:error] [pid 23291] [client 92.196.97.116:36634] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/photos/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/photos
[Tue Jul 06 04:31:41.436065 2021] [autoindex:error] [pid 4512] [client 92.196.97.116:36900] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/privacy/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/privacy
[Tue Jul 06 04:31:45.183985 2021] [autoindex:error] [pid 28757] [client 92.196.97.116:37138] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/provisioning_api/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/provisioning_api
[Tue Jul 06 04:31:51.361075 2021] [autoindex:error] [pid 23338] [client 92.196.97.116:37254] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/recommendations/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/recommendations
[Tue Jul 06 04:31:54.886345 2021] [autoindex:error] [pid 4089] [client 92.196.97.116:37458] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/serverinfo/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/serverinfo
[Tue Jul 06 04:32:00.355429 2021] [autoindex:error] [pid 4512] [client 92.196.97.116:37590] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/settings/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/settings
[Tue Jul 06 04:32:07.120313 2021] [autoindex:error] [pid 4511] [client 92.196.97.116:37912] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/sharebymail/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/sharebymail
[Tue Jul 06 04:32:16.854041 2021] [autoindex:error] [pid 5051] [client 92.196.97.116:38174] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/support/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/support
[Tue Jul 06 04:32:22.140722 2021] [autoindex:error] [pid 23291] [client 92.196.97.116:38432] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/survey_client/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/survey_client
[Tue Jul 06 04:32:30.443438 2021] [autoindex:error] [pid 21175] [client 92.196.97.116:38788] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/tasks/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/tasks
[Tue Jul 06 04:32:52.117622 2021] [autoindex:error] [pid 23338] [client 92.196.97.116:39520] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/text/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/text
[Tue Jul 06 04:32:59.330847 2021] [autoindex:error] [pid 29848] [client 92.196.97.116:39760] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/theming/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/theming
[Tue Jul 06 04:33:12.756487 2021] [autoindex:error] [pid 29876] [client 92.196.97.116:40254] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/twofactor_backupcodes/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/twofactor_backupcodes
[Tue Jul 06 04:33:36.954532 2021] [autoindex:error] [pid 29848] [client 92.196.97.116:41044] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/updatenotification/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/updatenotification
[Tue Jul 06 04:33:40.242927 2021] [autoindex:error] [pid 22620] [client 92.196.97.116:41290] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/viewer/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/viewer
[Tue Jul 06 04:33:48.469699 2021] [autoindex:error] [pid 28757] [client 92.196.97.116:41542] AH01276: Cannot serve directory /var/www/html/nextcloud/apps/workflowengine/: No matching DirectoryIndex (index.php,index.html) found, and server-generated directory index forbidden by Options directive, referer: https://editoor.ddns.net/apps/workflowengine
[Tue Jul 06 08:48:26.150597 2021] [access_compat:error] [pid 28757] [client 192.168.1.1:49804] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Tue Jul 06 09:24:48.823622 2021] [access_compat:error] [pid 21175] [client 192.168.1.1:49805] AH01797: client denied by server configuration: /var/www/html/nextcloud/config
[Tue Jul 06 17:07:38.950242 2021] [access_compat:error] [pid 897] [client 209.141.47.35:41014] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
[Tue Jul 06 21:29:01.347661 2021] [access_compat:error] [pid 16285] [client 205.185.120.237:52914] AH01797: client denied by server configuration: /var/www/html/nextcloud/config/getuser
