Hi ,
It seams like I have successfully connected to drop box and google drive in the admin section of nextcloud. when I try data migration for either I get reported data size in drop box and contacts caleders and drive shows up.
It says
1000 files in Google Drive (922 MiB + 396 MiB shared with you)
0 files imported (0%)
Google Drive background import process will begin soon. You can close this page. You will be notified when it finishes.
the same for drop box , but no files ever sync.
The files never download.
is it an issue that i am using S3 as primary storage ?
nextcloud on 20.0.8
ubuntu 20.04
Php 7
apache latest stable
mysql latest stable
I have logs of errors like this in the logging…
|Error|PHP|Error: fread(): read of 8192 bytes failed with errno=9 Bad file descriptor at /var/www/html/nextcloud/3rdparty/icewind/streams/src/Wrapper.php#91
- <>OC\Log\ErrorHandler::onError()
- /var/www/html/nextcloud/3rdparty/icewind/streams/src/Wrapper.php - line 91:fread()
- /var/www/html/nextcloud/3rdparty/icewind/streams/src/CallbackWrapper.php - line 98:Icewind\Streams\Wrapper->stream_read()
- <>Icewind\Streams\CallbackWrapper->stream_read()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/psr7/src/Stream.php - line 225:fread()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/psr7/src/functions.php - line 867:GuzzleHttp\Psr7\Stream->read()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php - line 127:GuzzleHttp\Psr7\get_message_body_summary()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Exception/RequestException.php - line 107:GuzzleHttp\Exception\RequestException::getResponseBodySummary()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php - line 65:GuzzleHttp\Exception\RequestException::create()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 203:GuzzleHttp\Middleware::GuzzleHttp{closure}("*** sensiti … *")
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 156:GuzzleHttp\Promise\Promise::callHandler()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 47:GuzzleHttp\Promise\Promise::GuzzleHttp\Promise{closure}("*** sensiti … *")
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 246:GuzzleHttp\Promise\TaskQueue->run()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 223:GuzzleHttp\Promise\Promise->invokeWaitFn()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 267:GuzzleHttp\Promise\Promise->waitIfPending()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 225:GuzzleHttp\Promise\Promise->invokeWaitList()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 62:GuzzleHttp\Promise\Promise->waitIfPending()
- /var/www/html/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php - line 183:GuzzleHttp\Promise\Promise->wait()
- /var/www/html/nextcloud/lib/private/Http/Client/Client.php - line 233:GuzzleHttp\Client->request()
- /var/www/html/nextcloud/apps/integration_google/lib/Service/GoogleAPIService.php - line 331:OC\Http\Client\Client->get()
- /var/www/html/nextcloud/apps/integration_google/lib/Service/GoogleDriveAPIService.php - line 373:OCA\Google\Service\GoogleAPIService->simpleDownload()
- /var/www/html/nextcloud/apps/integration_google/lib/Service/GoogleDriveAPIService.php - line 278:OCA\Google\Service\GoogleDriveAPIService->getFile()
- /var/www/html/nextcloud/apps/integration_google/lib/Service/GoogleDriveAPIService.php - line 160:OCA\Google\Service\GoogleDriveAPIService->importFiles()
- /var/www/html/nextcloud/apps/integration_google/lib/BackgroundJob/ImportDriveJob.php - line 36:OCA\Google\Service\GoogleDriveAPIService->importDriveJob()
- /var/www/html/nextcloud/lib/public/BackgroundJob/Job.php - line 80:OCA\Google\BackgroundJob\ImportDriveJob->run()
- /var/www/html/nextcloud/lib/public/BackgroundJob/QueuedJob.php - line 48:OCP\BackgroundJob\Job->execute()
- /var/www/html/nextcloud/cron.php - line 149:OCP\BackgroundJob\QueuedJob->execute()|
example
longer
example
here
Nextcloud version (eg, 20.0.5): replace me
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
PASTE HERE
PASTE HERE
PASTE HERE
