I’ve done some bad things again and for some reason nextcloudpi doesn’t want to work. I can get into ncp-config, but I cannot get into any of the web Gui’s.
When I attempt nc-backup I get the message
Error reading data directory. Is NextCloud running and configured?
Similarly when I run nc-fix-permissions I get:
data dir not found
I’m thinking this is a problem, but I have no idea how to solve it as my data is there.
I’m running nextcloudpi ver. 0.57.17 via docker on a raspberry pi. And I get this when I run nc-info (slightly edited to remove identifying information)
Gathering information...
NextCloudPi version v0.57.17
NextCloudPi image NextCloudPi_05-30-18
distribution Debian GNU/Linux 9 \n \l
USB devices sda sdb
datadir /data/app/data
data in SD no
data filesystem ext2/ext3
data disk usage 21G/166G
rootfs usage 1.4G/16G
swapfile /var/swap
dbdir /data/database
Nextcloud check error
HTTPD service down
PHP service up
MariaDB service down
Redis service up
Postfix service up
internet check ok
port check 80 closed
port check 443 closed
IP 172.17.0.2
gateway 172.17.0.1
interface eth0
certificates xxx.xxx.xxx
NAT loopback no
uptime 57min
Alright, I’m concerned about a few things here. For starters it shows the port checks are not working. I’m not sure what it does to check these ports, so this may be ok as I’m mapping 8080 to 80 in the container and 444 to 443 in the container. So if it’s doing some sort of ping out and back to itself… well it’s possible this is right and it doesn’t know it. But I’m thinking this is actually an issue.
Beyond that the HTTPD and MariaDB services are down and under “nextcloudcheck” it says error. How can I start these services?
Any idea what I might need to do to get this thing back and rolling?
