Hi
I’m looking for a way to custom Help menu.
We have a small documentation for our user, and i would like, Help menu link on it.
Is it possible to do it and how ?
thx
Hi
thx
I find a way to do what I want, but I’m not sure its the best way :
In /nextcloud/core/doc/user I put my customize user documentation in pdf format, give right to www-data:www-data (apache user of your distribution) on this file.
Then I modify the /nextcloud/core/doc/user/index.html file like this :
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Nextcloud 14 user manual introduction — Nextcloud 14 User Manual 14 documentation</title>
<link rel="stylesheet" href="_static/" type="text/css" />
<link rel="stylesheet" href="_static/pygments.css" type="text/css" />
<link rel="stylesheet" href="_static/main.min.css" type="text/css" />
<link rel="stylesheet" href="_static/styles.css" type="text/css" />
<script type="text/javascript">
var DOCUMENTATION_OPTIONS = {
URL_ROOT: './',
VERSION: '14',
COLLAPSE_INDEX: false,
FILE_SUFFIX: '.html',
HAS_SOURCE: true
</script>
<script type="text/javascript" src="_static/jquery.js"></script>
<script type="text/javascript" src="_static/underscore.js"></script>
<script type="text/javascript" src="_static/doctools.js"></script>
<script type="text/javascript" src="_static/js/jquery-1.11.0.min.js"></script>
<script type="text/javascript" src="_static/js/jquery-fix.js"></script>
<script type="text/javascript" src="_static/bootstrap-3.1.0/js/bootstrap.min.js"></script>
<script type="text/javascript" src="_static/bootstrap-sphinx.js"></script>
<link rel="top" title="Nextcloud 14 User Manual 14 documentation" href="contents.html" />
<link rel="next" title="What’s new for users in Nextcloud 14" href="whats_new.html" />
<link rel="prev" title="Table of contents" href="contents.html" />
<meta charset='utf-8'>
<meta http-equiv='X-UA-Compatible' content='IE=edge,chrome=1'>
<meta name='viewport' content='width=device-width, initial-scale=1.0, maximum-scale=1'>
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="theme-color" content="#1d2d44">
</head>
<body role="document">
<div class="wrap container not-front">
<iframe id="pdframe" style="width:100%;height:100%;display:block;position:absolute;top:0;z-index:1041;left:0;" src="/nextcloud/index.php/apps/files_pdfviewer/?file=%2Fnextcloud%2Fcore%2Fdoc%2Fuser%2FDocUtilisateur2.pdf" sandbox="allow-scripts allow-same-origin allow-popups allow-modals allow-top-navigation" allowfullscreen="true"></iframe>
</div>
</body>
</html>
Now when my user click on Help menu he get my customize help .pdf file.
cordialy
