Custom datadirectory and multi-users
I just installed NC on my Proxmox system, using a LXC from Turnkey.
  • I created a bind mount from my storage volume, by using this command:
    pct set 104 mp0 /Stockage/NextCloud,mp=/ncdata
  • I copied the content from nextcloud-data to /ncdata
  • I gave the permissions (recursive) to www-data on that folder, on the LXC
  • Then I edited config/config.php file so that datadirectory points to /ncdata
  • Finally restarted apache2 service
Up to that point, everything seems to be working as expected.
BUT… after that, in NC I created another user, disconnected and reconnected with that user, and now the default files are not showing anymore (even the user icon shows a cross); the names of the files are listed, but they are “empty”.
If I switch back to the admin user, all the files are visible.
So… when I create a new user, where are his files stored ? (I’d like to add their photo galleries under their own user data folders).
Regards.
