Hi there,
this issue has taken much of my time, so I decided to try to reach help here in the official nextcloud forum.
I have an nginx reverse proxy and behind there is an apache. It seems like there is a problem with CSRF. In advance: I am an advanced beginner in webserver configuration.
The failure is, that paths to https://cloud.mydomain.com/index.php/apps/notes/notes gets a 502 or 500 http status code and if I open the url directly there It says “Access denied. CSRF check failed”.
I have read many websites to that topic and nginx needs to forward http header informations to the apache. So I made some changes to the vhost config. Below there it is:
server {
listen 80;
listen 443 ssl http2;
ssl_certificate /usr/local/nginx/conf/ssl/cloud.mydomain.com.crt;
ssl_certificate_key /usr/local/nginx/conf/ssl/cloud.mydomain.com.key;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
ssl_session_cache builtin:1000 shared:SSL:10m;
ssl_buffer_size 1400;
add_header Strict-Transport-Security max-age=15768000;
ssl_stapling on;
ssl_stapling_verify on;
server_name cloud.bitpage.de;
access_log /data/wwwlogs/cloud.mydomain.com_nginx.log combined;
index index.html index.htm index.php;
root /data/wwwroot/cloud.mydomain.com;
if ($ssl_protocol = "") { return 301 https://$server_name$request_uri; }
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
proxy_connect_timeout 300s;
proxy_send_timeout 900;
proxy_read_timeout 900;
proxy_buffer_size 32k;
proxy_buffers 4 64k;
proxy_busy_buffers_size 128k;
proxy_redirect off;
proxy_hide_header Vary;
proxy_set_header Accept-Encoding '';
proxy_set_header Referer $http_referer;
proxy_set_header Cookie $http_cookie;
proxy_set_header Host $host;
proxy_buffering off;
proxy_request_buffering off;
proxy_pass_header Set-Cookie;
proxy_pass_header X-CSRF-TOKEN;
proxy_pass http://127.0.0.1:88;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js|woff|svg|gif)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into
# this topic first.
# add_header Strict-Transport-Security "max-age=15768000;
# includeSubDomains; preload;";
# could take several months.
add_header X-Frame-Options "SAMEORIGIN";
add_header X-Robots-Tag none;
access_log off;
location ~* \.(?:png|html|ttf|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
The corresponding apache vhost:
<VirtualHost *:88>
ServerAdmin admin@example.com
DocumentRoot "/data/wwwroot/cloud.mydomain.com"
ServerName cloud.mydomain.com
SSLEngine on
SSLCertificateFile "/usr/local/nginx/conf/ssl/cloud.mydomain.com.crt"
SSLCertificateKeyFile "/usr/local/nginx/conf/ssl/cloud.mydomain.com.key"
ErrorLog "/data/wwwlogs/cloud.mydomain.com_error_apache.log"
CustomLog "/data/wwwlogs/cloud.mydomain.com_apache.log" common
<Directory "/data/wwwroot/cloud.mydomain.com">
SetOutputFilter DEFLATE
Options FollowSymLinks ExecCGI
Require all granted
AllowOverride All
Order allow,deny
Allow from all
DirectoryIndex index.html index.php
</Directory>
</VirtualHost>
In the apache access log there I found an entry:
127.0.0.1 88.76.xxx.xx - - [28/May/2017:21:12:43 +0800] "GET /index.php/apps/notes/notes HTTP/1.0" 500 16889
So it seems like my correct user IP is relayed because the server ID starts with 81.xxx…
my config/config.php looks like this:
'instanceid' => 'ocxxxpxwapx6',
'passwordsalt' => '2xs8+fNe6JTfD//gR51zc9whIBiRBX',
'secret' => 'I+Iej2gq8k5u5ZFuMkWoherhgwL+4ohBYnqT21lpQVfntXul',
0 => 'cloud.mydomain.com',
1 => 'http://127.0.0.1:88',
2 => 'localhost',
3 => 'localhost:88',
4 => 'http://127.0.0.1',
'datadirectory' => '/data/wwwroot/nextcloud-data',
'trusted_proxies' => ['http://127.0.0.1'],
'overwrite.cli.url' => 'https://cloud.mydomain.com',
'overwritehost' => 'cloud.mydomain.com',
'enable_avatars' => true,
'version' => '11.0.3.2',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'removed',
'logtimezone' => 'UTC',
'mail_smtpmode' => 'php',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'cloud-mydomain',
'mail_domain' => 'myhoster.com',
'mail_smtpauth' => 1,
'mail_smtpname' => 'mail@mydomain.com',
'mail_smtppassword' => 'removed',
'mail_smtphost' => 'mail.mydomain.com',
'updater.secret' => '$2y$100$KAs7brOtj6uldSak5miUjeq16CfISLPQBtw3ePhiEJ1RpHWAw6BjW',
'theme' => '',
'loglevel' => 2,
Hint: I have anonymized the output here… but the configuration is left
Do you have an idea where could be the failure?
I don’t think it will rely on that, but there is also a php failure that the extension sysvmsg.so cannot be found, but i think that is another topic…
