Hi all,
After a recent upgrade of 5 separate NC instances I run to 21.0.0, I noticed (it’s possible that it was affecting older versions, too) via web dev tools that all my sites (that are otherwise appearing to run as expected) are showing the JS error Content Security Policy: The page’s settings blocked the loading of a resource at inline (“script-src”).
for both the fingerprint-protection.js and content-script.js scripts. I terminate my SSL at my Nginx reverse proxy, and use Docker Compose to run my NextCloud FPM container as well as an FPM Cron, Redis, and Nginx containers.
My current Nginx config is
worker_processes auto;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
keepalive_timeout 65;
set_real_ip_from 10.0.0.0/8;
set_real_ip_from 172.16.0.0/12;
set_real_ip_from 192.168.0.0/16;
real_ip_header X-Real-IP;
upstream php-handler {
server app:9000;
server {
listen 80;
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/html;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
# fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ {
# Optional: Don't log access to other assets
access_log off;
and my Nginx proxy config
server {
listen 80;
listen [::]:80;
server_name [sitename];
include includes/letsencrypt.conf;
# redirect all HTTP traffic to HTTPS.
location / {
return 302 https://[sitename]$request_uri;
# This configuration assumes that there's an nginx container talking to the mautic PHP-fpm container,
# and this is a reverse proxy for that Mautic instance.
server {
listen 443 ssl;
listen [::]:443 ssl;
ssl_certificate /etc/letsencrypt/live/[sitename]/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/[sitename]/privkey.pem;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
# to create this, see https://raymii.org/s/tutorials/Strong_SSL_Security_On_nginx.html
ssl_dhparam /etc/ssl/certs/dhparam.pem;
keepalive_timeout 20s;
include /etc/nginx/includes/letsencrypt.conf;
location /.well-known/carddav {
location /.well-known/caldav {
location ^~ / {
# I use 8082 here because 8080 & 8081 are already in use by other services
proxy_pass http://127.0.0.1:8082;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Proto 'https';
proxy_read_timeout 36000s;
add_header Front-End-Https on;
client_max_body_size 2G;
Also, to solve past issues (probably related to linking to OnlyOffice and CollaboraOffice instances), I’ve set the following in config/config.php:
'overwrite.cli.url' => 'https://[sitename]',
Note [sitename] is replaced by the actual FQDN for the various sites’ configs.
There are a few other Javascript-related issues, although I suspect they might be due to the missing JS files blocked by CSP…
I’ve tried a variety of “add_header Content-Security-Policy” directives in both the base Nginx and proxy configs, but none seem to have made any difference to this problem. Also, I’ve checked that the PHP user (www-data) can see all the files, i.e. I don’t think it’s a permissions error.
Any insights would be much appreciated!
I should note my systems are all running on cloud VMs running Ubuntu Linux 18.04 or 20.04…
