Nextcloud version (eg, 18.0.2): 19.0.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.1): PHP 7.4.9
Cronjob not working…
Yes
Okey…
I am trying to install Nextcloud with a script atm and I am getting that the Cronjob haven’t run in over 50 years right after the installation is completed (No… I didn’t wait 50 years. )
The code that I use:
echo "Creating crojobs for Nextcloud"
sudo echo "*/5 * * * * php -f /var/www/html/nextcloud/cron.php" >> /var/spool/cron/crontabs/www-data
sudo -u www-data php /var/www/html/nextcloud/occ background:cron
The weird part is that If i go to CLI and do to the crontab
sudo crontab -u www-data -e
and just saves again without editing anything, it will start to work again.
Any idea’s how I can fix this so I don’t need to do that step? So that it is 100% automated?
Thanks in advance!
/Rojz
EDIT:
After the installation on the Nextcloud I did even wait 5+ min jus to see if the cron would kick in, but it didn’t. only kicks in after i save the file again.
