example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.12
Operating system and version (eg, Ubuntu 20.04): Opensuse Leap 15.4
Apache or nginx version (eg, Apache 2.4.25): 2.4.51
PHP version (eg, 7.4): 7.4
I have Nextcloud Hub II (23.0.12) on a Opensuse Leap 15.4
Recently I see a warning that cron have not been running for a while.
I had a entry in /etc/crontab setting the id to run to wwwrun (my apache user) it failed because “wwrun password have expired”. I made some changes and move the entry to the wwwrun crontab
aldebaran:/srv/www/htdocs/nextcloud # crontab -u wwwrun -l
*/5 * * * * /usr/bin/php -f /srv/www/htdocs/nextcloud/cron.php >/srv/www/htdocs/nextcloud/data/cron.log 2>&1
I added the redirection to cron.log to test what happen.
The file cron.log is touched every 5 minutes, so the crontab job is working, but the cron.log remains empty.
If I run
aldebaran:/srv/www/htdocs/nextcloud # sudo -u wwwrun /usr/bin/php -f /srv/www/htdocs/nextcloud/cron.php
It does not return any error … but it does not return anything. And still it does not work
Same if I change cron to webcron and I enter in a browser
https://myserver/nextcloud/cron.php
it does not return any error but it shows a blank page.
What can I test?
