I am still having an issue where cron does not appear to be running as the UI still shows a warning " Some jobs have not been executed since a day ago. Please consider increasing the execution frequency." under the Background Jobs page.
I have run the initial crontab command with the tag “-u www-data” as this matches the fine print " The cron.php needs to be executed by the system account “www-data”." that appears in the web UI.
I have added the apc.enable command so that the command is:
*/5 * * * * /usr/bin/php8.3 --define apc.enable_cli=1 -f /var/www/html/cron.php
I have also ran “crontab -u www-data -l” and I do get the return
[snip]
*/5 * * * * php -f /var/www/nextcloud/cron.php
I have also ran “sudo -u www-data php /var/www/html/cron.php” to try and manually run, but the error still remains.
I have also set my log level to 1, to check for any errors related to cron, but nothing is appearing.
Unclear why you use a cron job for those. You enable most on the server once.
Try an PHP undependend command:
/usr/bin/wget -O /dev/null -q https://cloud.yourdomain.xx/cron.php
/usr/bin/wget -O /dev/null -q https://cloud.yourdomain.xx/occ dav:send-event-reminders
The last one is for the calendars to send allerts.
You can enter these commands SSH to test. Leave out -q then to see what happens.
I am certain that nextcloud is installed in /var/ww/html, not in /var/www/nextcloud (I’m aware that the docs has it installed in /var/www/nextcloud).
When I run “crontab -u www-data -l”, I do get “*/5 * * * * /usr/bin/php8.3 --define apc.enable_cli=1 -f /var/www/html/cron.php” as a return which the docs says can be used to verify cron is running.
Edit: it appears that it’s running correctly now, or at least the message is updating saying that it ran in the last 5 minutes.
I’m not sure what I did to fix, I tried a few more things (resetting some settings, readding flags, etc), to anyone with a similar future problem I can only recommend following the docs exactly…
