Covering Calendars possible after loss of hardware?
Hej guys
I lost my Nextcloud hardware due to hardware defects. I backed up all except my calendars. There is no way to access on hardware itself. Lost.
I use Google calendar on my mobile device. I still can see all the calendars and their data in it which I have implemented with DAVx. Now I try to find a way to export them.
I did not find the option to export them from Google Calendar app nor DAVx.
Does anyone know a solution to keep these data? Maybe other apps which can read current data from Google app or DAVx?
Kind regards
//nephilim
Should be possible to export the Google calenders.
I would ask at the Google Calendar Community.
