Hello there,
I am trying to install Nextcloud and straight after providing the admin infoo and the database info, the installer tries to take me to the login screen but I get a wierd error :
“url”: “/volunteers/index.php/login”,
“message”: {
“Exception”: “OCP\AppFramework\QueryException”,
“Message”: “Could not resolve apiService! Class apiService does not exist”,
“Code”: 0,
Could anybody help me out? I have no idea what to do.
Thanks for any help.
E
“reqId”: “XpRopFKlVCEAAJu5kwYAAAAJ”,
“level”: 3,
“time”: “2020-04-13T13:27:00+00:00”,
“remoteAddr”: “88.121.29.140”,
“user”: “–”,
“app”: “index”,
“method”: “GET”,
“message”: {
“Code”: 0,
“Trace”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/Utility/SimpleContainer.php”,
“line”: 115,
“function”: “resolve”,
“class”: “OC\AppFramework\Utility\SimpleContainer”,
“type”: “->”,
“args”: [
“apiService”
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/ServerContainer.php”,
“line”: 150,
“function”: “query”,
“type”: “->”,
“args”: [
“apiService”,
true
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/DependencyInjection/DIContainer.php”,
“line”: 389,
“class”: “OC\ServerContainer”,
“type”: “->”,
“args”: [
“apiService”,
true
“line”: 77,
“class”: “OC\AppFramework\DependencyInjection\DIContainer”,
“type”: “->”,
“args”: [
“apiService”
“line”: 100,
“function”: “buildClass”,
“type”: “->”,
“args”: [
“name”: “OCA\Text\DirectEditing\TextDirectEditor”,
“class”: “ReflectionClass”
“line”: 115,
“type”: “->”,
“args”: [
“line”: 415,
“type”: “->”,
“args”: [
“line”: 386,
“function”: “queryNoFallback”,
“type”: “->”,
“args”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/apps/text/lib/AppInfo/Application.php”,
“line”: 68,
“type”: “->”,
“args”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/3rdparty/symfony/event-dispatcher/EventDispatcher.php”,
“line”: 247,
“function”: “OCA\Text\AppInfo\{closure}”,
“class”: “OCA\Text\AppInfo\Application”,
“type”: “->”,
“args”: [
“*** sensitive parameters replaced "
“line”: 73,
“function”: “callListeners”,
“class”: “Symfony\Component\EventDispatcher\EventDispatcher”,
“type”: “->”,
“args”: [
“class”: “Closure”
" sensitive parameter replaced ",
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/EventDispatcher/EventDispatcher.php”,
“line”: 80,
“function”: “dispatch”,
“type”: “->”,
“args”: [
“line”: 92,
“class”: “OC\EventDispatcher\EventDispatcher”,
“type”: “->”,
“args”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/apps/files/lib/Service/DirectEditingService.php”,
“line”: 52,
“function”: “dispatchTyped”,
“type”: “->”,
“args”: [
" sensitive parameter replaced ***”
“line”: 48,
“function”: “getDirectEditingCapabilitites”,
“class”: “OCA\Files\Service\DirectEditingService”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/apps/files/lib/Capabilities.php”,
“line”: 79,
“function”: “getDirectEditingETag”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/CapabilitiesManager.php”,
“line”: 71,
“function”: “getCapabilities”,
“class”: “OCA\Files\Capabilities”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/Template/JSConfigHelper.php”,
“line”: 177,
“class”: “OC\CapabilitiesManager”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/TemplateLayout.php”,
“line”: 190,
“function”: “getConfig”,
“class”: “OC\Template\JSConfigHelper”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/legacy/template.php”,
“line”: 184,
“function”: “__construct”,
“class”: “OC\TemplateLayout”,
“type”: “->”,
“args”: [
“guest”,
“core”
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/public/AppFramework/Http/TemplateResponse.php”,
“line”: 167,
“function”: “fetchPage”,
“class”: “OC_Template”,
“type”: “->”,
“args”: [
“alt_login”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/Http/Dispatcher.php”,
“line”: 123,
“function”: “render”,
“class”: “OCP\AppFramework\Http\TemplateResponse”,
“type”: “->”,
“args”: []
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/App.php”,
“line”: 125,
“class”: “OC\AppFramework\Http\Dispatcher”,
“type”: “->”,
“args”: [
“class”: “OC\Core\Controller\LoginController”
“showLoginForm”
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/Routing/RouteActionHandler.php”,
“line”: 47,
“function”: “main”,
“class”: “OC\AppFramework\App”,
“type”: “::”,
“args”: [
“OC\Core\Controller\LoginController”,
“showLoginForm”,
“_route”: “core.login.showLoginForm”
“function”: “__invoke”,
“class”: “OC\AppFramework\Routing\RouteActionHandler”,
“type”: “->”,
“args”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/Route/Router.php”,
“line”: 299,
“function”: “call_user_func”,
“args”: [
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/base.php”,
“line”: 1008,
“function”: “match”,
“class”: “OC\Route\Router”,
“type”: “->”,
“args”: [
“/login”
“file”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/index.php”,
“line”: 38,
“function”: “handleRequest”,
“class”: “OC”,
“type”: “::”,
“args”: []
“File”: “/homepages/2/d79441987/htdocs/Sites/pramod/vhmavi.edu.np/volunteers/lib/private/AppFramework/Utility/SimpleContainer.php”,
“Line”: 106,
“CustomMessage”: “–”
“userAgent”: “Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/13.1 Safari/605.1.15”,
“version”: “18.0.3.0”
