Mein user hat gar keine Widgets aktiv (alle ohne Häkchen).
Hier die beiden vollständigen Fehlerzeilen aus dem Log.
Dashboard widget with this id has already been registered
{"reqId":"ZCpqnTohaPL_JDSd9AsxyQAAJw8","level":3,"time":"2023-04-03T05:56:45+00:00","remoteAddr":"xxx.xxx.xxx.xxx","user":"yyyyyy","app":"no app in context","method":"GET","url":"/cloud/index.php/apps/dashboard/","message":"Could not register lazy dashboard widget: Dashboard widget with this id has already been registered","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36","version":"25.0.5.1","exception":{"Exception":"InvalidArgumentException","Message":"Dashboard widget with this id has already been registered","Code":0,"Trace":[{"file":"/pfad/cloud/lib/private/Dashboard/Manager.php","line":94,"function":"registerWidget","class":"OC\\Dashboard\\Manager","type":"->","args":[["OCA\\Recommendations\\Dashboard\\RecommendationWidget"]]},{"file":"/pfad/cloud/lib/private/Dashboard/Manager.php","line":131,"function":"loadLazyPanels","class":"OC\\Dashboard\\Manager","type":"->","args":[]},{"file":"/pfad/cloud/apps/dashboard/lib/Controller/DashboardController.php","line":101,"function":"getWidgets","class":"OC\\Dashboard\\Manager","type":"->","args":[]},{"file":"/pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"index","class":"OCA\\Dashboard\\Controller\\DashboardController","type":"->","args":[]},{"file":"/pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Dashboard\\Controller\\DashboardController"],"index"]},{"file":"/pfad/cloud/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Dashboard\\Controller\\DashboardController"],"index"]},{"file":"/pfad/cloud/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Dashboard\\Controller\\DashboardController","index",["OC\\AppFramework\\DependencyInjection\\DIContainer"],["dashboard.dashboard.index"]]},{"file":"/pfad/cloud/lib/base.php","line":1047,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/dashboard/"]},{"file":"/pfad/cloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/pfad/cloud/lib/private/Dashboard/Manager.php","Line":55,"message":"Could not register lazy dashboard widget: Dashboard widget with this id has already been registered","exception":{},"CustomMessage":"Could not register lazy dashboard widget: Dashboard widget with this id has already been registered"}}
Could not resolve l10n!
{"reqId":"ZCprsyRAmLA_UQfFbkx5tgAABQA","level":3,"time":"2023-04-03T06:01:23+00:00","remoteAddr":"xxx.xxx.xxx.xxx","user":"yyyyyy","app":"no app in context","method":"GET","url":"/cloud/index.php/apps/dashboard/","message":"Could not load lazy dashboard widget: Could not resolve l10n! Class \"l10n\" does not exist","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36","version":"25.0.5.1","data":{"excepiton":"{\"class\":\"OCP\\AppFramework\\QueryException\",\"message\":\"Could not resolve l10n! Class \\\"l10n\\\" does not exist\",\"code\":0,\"file\":\"/pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php:102\",\"trace\":\"#0 [internal function]: OC\\AppFramework\\Utility\\SimpleContainer->OC\\AppFramework\\Utility\\{closure}(Object(ReflectionParameter))\\n#1 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): array_map(Object(Closure), Array)\\n#2 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(116): OC\\AppFramework\\Utility\\SimpleContainer->buildClass(Object(ReflectionClass))\\n#3 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(133): OC\\AppFramework\\Utility\\SimpleContainer->resolve('OCA\\\\Talk\\\\Dashbo...')\\n#4 /pfad/cloud/lib/private/ServerContainer.php(161): OC\\AppFramework\\Utility\\SimpleContainer->query('OCA\\\\Talk\\\\Dashbo...', true)\\n#5 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\\ServerContainer->query('OCA\\\\Talk\\\\Dashbo...')\\n#6 /pfad/cloud/lib/private/Dashboard/Manager.php(78): OC\\AppFramework\\Utility\\SimpleContainer->get('OCA\\\\Talk\\\\Dashbo...')\\n#7 /pfad/cloud/lib/private/Dashboard/Manager.php(131): OC\\Dashboard\\Manager->loadLazyPanels()\\n#8 /pfad/cloud/apps/dashboard/lib/Controller/DashboardController.php(101): OC\\Dashboard\\Manager->getWidgets()\\n#9 /pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php(225): OCA\\Dashboard\\Controller\\DashboardController->index()\\n#10 /pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php(133): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Dashboard\\Controller\\DashboardController), 'index')\\n#11 /pfad/cloud/lib/private/AppFramework/App.php(172): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Dashboard\\Controller\\DashboardController), 'index')\\n#12 /pfad/cloud/lib/private/Route/Router.php(298): OC\\AppFramework\\App::main('OCA\\\\Dashboard\\\\C...', 'index', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\\n#13 /pfad/cloud/lib/base.php(1047): OC\\Route\\Router->match('/apps/dashboard...')\\n#14 /pfad/cloud/index.php(36): OC::handleRequest()\\n#15 {main}\",\"previous\":{\"class\":\"OCP\\AppFramework\\QueryException\",\"message\":\"Could not resolve OCP\\IL10N! Class can not be instantiated\",\"code\":0,\"file\":\"/pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php:118\",\"trace\":\"#0 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(133): OC\\AppFramework\\Utility\\SimpleContainer->resolve('OCP\\\\IL10N')\\n#1 /pfad/cloud/lib/private/ServerContainer.php(161): OC\\AppFramework\\Utility\\SimpleContainer->query('OCP\\\\IL10N', true)\\n#2 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(89): OC\\ServerContainer->query('OCP\\\\IL10N', true)\\n#3 [internal function]: OC\\AppFramework\\Utility\\SimpleContainer->OC\\AppFramework\\Utility\\{closure}(Object(ReflectionParameter))\\n#4 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): array_map(Object(Closure), Array)\\n#5 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(116): OC\\AppFramework\\Utility\\SimpleContainer->buildClass(Object(ReflectionClass))\\n#6 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(133): OC\\AppFramework\\Utility\\SimpleContainer->resolve('OCA\\\\Talk\\\\Dashbo...')\\n#7 /pfad/cloud/lib/private/ServerContainer.php(161): OC\\AppFramework\\Utility\\SimpleContainer->query('OCA\\\\Talk\\\\Dashbo...', true)\\n#8 /pfad/cloud/lib/private/AppFramework/Utility/SimpleContainer.php(57): OC\\ServerContainer->query('OCA\\\\Talk\\\\Dashbo...')\\n#9 /pfad/cloud/lib/private/Dashboard/Manager.php(78): OC\\AppFramework\\Utility\\SimpleContainer->get('OCA\\\\Talk\\\\Dashbo...')\\n#10 /pfad/cloud/lib/private/Dashboard/Manager.php(131): OC\\Dashboard\\Manager->loadLazyPanels()\\n#11 /pfad/cloud/apps/dashboard/lib/Controller/DashboardController.php(101): OC\\Dashboard\\Manager->getWidgets()\\n#12 /pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php(225): OCA\\Dashboard\\Controller\\DashboardController->index()\\n#13 /pfad/cloud/lib/private/AppFramework/Http/Dispatcher.php(133): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Dashboard\\Controller\\DashboardController), 'index')\\n#14 /pfad/cloud/lib/private/AppFramework/App.php(172): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Dashboard\\Controller\\DashboardController), 'index')\\n#15 /pfad/cloud/lib/private/Route/Router.php(298): OC\\AppFramework\\App::main('OCA\\\\Dashboard\\\\C...', 'index', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\\n#16 /pfad/cloud/lib/base.php(1047): OC\\Route\\Router->match('/apps/dashboard...')\\n#17 /pfad/cloud/index.php(36): OC::handleRequest()\\n#18 {main}\"}}"}}
