example
longer
example
here
Nextcloud version (eg, 12.0.2):
Operating system and version (eg, Ubuntu 17.04):
PHP version (eg, 7.1):
- Share a folder that contains files and subfolders with “Allows Uploading and Editing” checked
- Open shared folder via copied or emailed link
- Contents of the subfolders are not visible. “Download all files” creates a .zip with the folder structure as expected; they are jut not visible within the webrowser.
Nothing shown.
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'share.domain.com',
'datadirectory' => '/var/nextcloud/data',
'version' => '15.0.6.1',
'overwrite.cli.url' => 'https://share.domain.com/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'a user',
'dbpassword' => 'a password',
'redis' =>
'port' => 0,
'timeout' => 0.0,
'htaccess.RewriteBase' => '/nextcloud',
'mail_from_address' => 'mail user',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'mailserver.net',
'mail_smtphost' => '10.110.1.4',
'mail_smtpport' => '25',
'remember_login_cookie_lifetime' => 0,
'session_lifetime' => 600,
'session_keepalive' => false,
'skeletondirectory' => '/var/nextcloud/data/custskeleton',
'ldapIgnoreNamingRules' => false,
'twofactor_enforced' => 'true',
0 => 'group1',
1 => 'group2',
As shown in the picture this is the contents of the folder that was shared. I am unable to see the contents in the browser for either “New Folder” or “Test”. Multiple browsers, Desktop and Mobile, have been tested.
