Connection to StorageGRID not possible
example
longer
example
here
Nextcloud version (eg, 20.0.5): 21.0.2.1
Operating system and version (eg, Ubuntu 20.04): CentOS 8
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.1
PHP version (eg, 7.4): 7.4.20
After an upgrade of StorageGRID to version 11.5 I can’t connect to the external S3 storage.
I try to connect to the Nextcloud instance page and nothing happens. When I remove the objectstore configuration, everything works as expected.
  1. Put the objectstore configuration snippet in config.php
{"reqId":"9MYlPZUF4dB1tUpcvvbP","level":2,"time":"2021-06-21T08:40:06+00:00","remoteAddr":"192.168.103.17","user":"--","app":"no app in context","method":"GET","url":"/","message":"Could not detect any host in http:///data/htaccesstest.txt","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0","version":""}
{"reqId":"9MYlPZUF4dB1tUpcvvbP","level":2,"time":"2021-06-21T08:40:06+00:00","remoteAddr":"192.168.103.17","user":"--","app":"no app in context","method":"GET","url":"/","message":"Could not detect any host in https:///data/htaccesstest.txt","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0","version":""}
{"reqId":"cTaitjQjwfcGYNerbm7I","level":2,"time":"2021-06-21T08:42:44+00:00","remoteAddr":"192.168.103.17","user":"--","app":"no app in context","method":"POST","url":"/index.php","message":"Could not detect any host in http:///data/htaccesstest.txt","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0","version":""}
{"reqId":"cTaitjQjwfcGYNerbm7I","level":2,"time":"2021-06-21T08:42:44+00:00","remoteAddr":"192.168.103.17","user":"--","app":"no app in context","method":"POST","url":"/index.php","message":"Could not detect any host in https:///data/htaccesstest.txt","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0","version":""}
{"reqId":"ugJdKfy2IUVsZXj72Uoq","level":3,"time":"2021-06-21T08:52:14+00:00","remoteAddr":"192.168.103.17","user":"admin","app":"index","method":"GET","url":"/settings/ajax/checksetup","message":{"Exception":"Exception","Message":"Call to undefined function OCA\\Settings\\Controller\\posix_getuid()","Code":0,"Trace":[{"file":"/data/web/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/data/web/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/data/web/nextcloud/lib/base.php","line":993,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/data/web/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/data/web/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","Line":159,"Previous":{"Exception":"Error","Message":"Call to undefined function OCA\\Settings\\Controller\\posix_getuid()","Code":0,"Trace":[{"file":"/data/web/nextcloud/apps/settings/lib/Controller/CheckSetupController.php","line":757,"function":"getAppDirsWithDifferentOwner","class":"OCA\\Settings\\Controller\\CheckSetupController","type":"->"},{"file":"/data/web/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":218,"function":"check","class":"OCA\\Settings\\Controller\\CheckSetupController","type":"->"},{"file":"/data/web/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":127,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/data/web/nextcloud/lib/private/AppFramework/App.php","line":157,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/data/web/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/data/web/nextcloud/lib/base.php","line":993,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/data/web/nextcloud/index.php","line":37,"function":"handleRequest","class":"OC","type":"::"}],"File":"/data/web/nextcloud/apps/settings/lib/Controller/CheckSetupController.php","Line":560},"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:89.0) Gecko/20100101 Firefox/89.0","version":"21.0.2.1"}
  'instanceid' => '***REMOVED SENSITIVE VALUE***',
  'passwordsalt' => '***REMOVED SENSITIVE VALUE***',
  'secret' => '***REMOVED SENSITIVE VALUE***',
    0 => 'domain.lan:8080',
  'datadirectory' => '/data/web/nextcloud/data',
  'version' => '21.0.2.1',
  'overwrite.cli.url' => 'http://domain.lan:8080',
  'dbname' => '***REMOVED SENSITIVE VALUE***',
  'dbhost' => '***REMOVED SENSITIVE VALUE***',
  'dbuser' => '***REMOVED SENSITIVE VALUE***',
  'dbpassword' => '***REMOVED SENSITIVE VALUE***',
  'objectstore' =>
    'class' => '\\OC\\Files\\ObjectStore\\S3',
    'arguments' =>
      'bucket' => 'test-bucket',
      'autocreate' => true,
      'key' => '***REMOVED SENSITIVE VALUE***',
      'hostname' => 's3storage.lan',
      'port' => 80,
      'use_ssl' => false,
      'region' => 'us-east-1',
      'use_path_style' => true,
nothing useful
First make sure you can access the bucket from the same (or similar) host using S3 CLI or some other client.
If that works with the same settings, then it could be something in the plugin or setup steps.
I can’t think of any changes in StorageGRID 11.5 that would make HTTP stop working. Noteworthy changes in SG 11.5 are documented here.
You could use tcpdump or wireshark to capture traffic to s3.storage.lan:80 to see what’s happening when NextCloud starts. Because you’re using HTTP and not HTTPS, it should be quite easy.
