Hardware: Raspberry pi 3b+
Software: NextcloudPI
NC Version: 14.0.4 RC 2
problem; Every 10-15min or so i get the message Connection lost, and then the webui isn’t reachable for 1-2min and it goes back on, 10min later it gets again connection lost etc…
ps: there is nothing wrong with my internet. can anyone help me with this, thank you
there is only 1 error in the logging:
Error no app in context RedisException: Connection lost
0./var/www/nextcloud/lib/private/Memcache/Redis.php - line 54:
Redis->get(“ae20da7a355 … s”)
1./var/www/nextcloud/lib/autoloader.php - line 150:
OC\Memcache\Redis->get(“OC_Defaults”)
OC\Autoloader->load(“OC_Defaults”)
3./var/www/nextcloud/apps/theming/lib/ThemingDefaults.php - line 45:
spl_autoload_call(“OC_Defaults”)
4./var/www/nextcloud/lib/composer/composer/ClassLoader.php - line 444:
include("/var/www/ne … p")
5./var/www/nextcloud/lib/composer/composer/ClassLoader.php - line 322:
Composer\Autoload\includeFile("/var/www/ne … p")
Composer\Autoload\ClassLoader->loadClass(“OCA\Theming\ThemingDefaults”)
7./var/www/nextcloud/lib/private/Server.php - line 946:
spl_autoload_call(“OCA\Theming\ThemingDefaults”)
8./var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:
OC\Server->OC{closure}("*** sensiti … *")
9./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117:
Pimple\Container->offsetGet(“ThemingDefaults”)
10./var/www/nextcloud/lib/private/ServerContainer.php - line 132:
OC\AppFramework\Utility\SimpleContainer->query(“ThemingDefaults”)
11./var/www/nextcloud/lib/private/Server.php - line 1858:
OC\ServerContainer->query(“ThemingDefaults”)
12./var/www/nextcloud/lib/private/Server.php - line 1141:
OC\Server->getThemingDefaults()
13./var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:
14./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117:
Pimple\Container->offsetGet(“OCP\Defaults”)
15./var/www/nextcloud/lib/private/ServerContainer.php - line 132:
OC\AppFramework\Utility\SimpleContainer->query(“OCP\Defaults”)
16./var/www/nextcloud/lib/private/Server.php - line 826:
OC\ServerContainer->query(“OCP\Defaults”)
17./var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:
18./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117:
Pimple\Container->offsetGet(“OCP\Mail\IMailer”)
19./var/www/nextcloud/lib/private/ServerContainer.php - line 132:
OC\AppFramework\Utility\SimpleContainer->query(“OCP\Mail\IMailer”)
20./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 165:
OC\ServerContainer->query(“OCP\Mail\IMailer”)
21./var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 114:
OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility{closure}("*** sensiti … *")
22./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117:
Pimple\Container->offsetGet(“Mailer”)
23./var/www/nextcloud/lib/private/ServerContainer.php - line 132:
OC\AppFramework\Utility\SimpleContainer->query(“Mailer”)
24./var/www/nextcloud/lib/private/Server.php - line 1713:
OC\ServerContainer->query(“Mailer”)
25./var/www/nextcloud/lib/private/Server.php - line 1057:
OC\Server->getMailer()
26./var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php - line 118:
27./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 117:
Pimple\Container->offsetGet(“OCP\Share\IManager”)
28./var/www/nextcloud/lib/private/ServerContainer.php - line 132:
OC\AppFramework\Utility\SimpleContainer->query(“OCP\Share\IManager”)
29./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 427:
OC\ServerContainer->query(“OCP\Share\IManager”)
30./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 68:
OC\AppFramework\DependencyInjection\DIContainer->query(“OCP\Share\IManager”)
31./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 98:
OC\AppFramework\Utility\SimpleContainer->buildClass(ReflectionCl … "})
32./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 119:
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\DAV\C … l”)
33./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 453:
OC\AppFramework\Utility\SimpleContainer->query(“OCA\DAV\C … l”)
34./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 424:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\DAV\C … l”)
35./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 68:
OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\DAV\C … l”)
36./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 98:
37./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 119:
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\DAV\C … d”)
38./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 453:
OC\AppFramework\Utility\SimpleContainer->query(“OCA\DAV\C … d”)
39./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 424:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\DAV\C … d”)
40./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 68:
OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\DAV\C … d”)
41./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 98:
42./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 119:
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\DAV\C … e”)
43./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 453:
OC\AppFramework\Utility\SimpleContainer->query(“OCA\DAV\C … e”)
44./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 424:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\DAV\C … e”)
45./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 68:
OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\DAV\C … e”)
46./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 98:
47./var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 119:
OC\AppFramework\Utility\SimpleContainer->resolve(“OCA\DAV\HookManager”)
48./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 453:
OC\AppFramework\Utility\SimpleContainer->query(“OCA\DAV\HookManager”)
49./var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 424:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback(“OCA\DAV\HookManager”)
50./var/www/nextcloud/apps/dav/lib/AppInfo/Application.php - line 99:
OC\AppFramework\DependencyInjection\DIContainer->query(“OCA\DAV\HookManager”)
51./var/www/nextcloud/apps/dav/appinfo/app.php - line 31:
OCA\DAV\AppInfo\Application->registerHooks()
52./var/www/nextcloud/lib/private/legacy/app.php - line 261:
require_once("/var/www/ne … p")
53./var/www/nextcloud/lib/private/legacy/app.php - line 154:
OC_App::requireAppFile(OCA\DAV\AppInfo\Application {})
54./var/www/nextcloud/lib/private/legacy/app.php - line 127:
OC_App::loadApp(“dav”)
55./var/www/nextcloud/lib/base.php - line 972:
OC_App::loadApps()
56./var/www/nextcloud/index.php - line 42:
OC::handleRequest()
