as i wrote the webhosting support mentioned usage of too much ram, so I set it to 128mb (minimum requirement as mentioned in NC docs) to see if that helps, which didnt so it’s back to 512mb.
Could it help to use php8? what’s the best php version to use?
php config:
PHP Version 7.4.32
System Linux xxxx.xxx.xxx 3.10.0-962.3.2.lve1.5.68.el7.x86_64 #1 SMP Wed Apr 6 11:12:23 UTC 2022 x86_64
Build Date Sep 29 2022 15:18:09
Configure Command './configure' '--disable-dependency-tracking' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/libexec' '--sharedstatedir=/var/lib' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-linux-gnu' '--target=x86_64-redhat-linux-gnu' '--program-prefix=' '--prefix=/opt/alt/php74' '--exec-prefix=/opt/alt/php74' '--bindir=/opt/alt/php74/usr/bin' '--sbindir=/opt/alt/php74/usr/sbin' '--sysconfdir=/opt/alt/php74/etc' '--datadir=/opt/alt/php74/usr/share' '--includedir=/opt/alt/php74/usr/include' '--libdir=/opt/alt/php74/usr/lib64' '--libexecdir=/opt/alt/php74/usr/libexec' '--localstatedir=/var' '--with-curl=/opt/alt/curlssl11/usr' '--sharedstatedir=/usr/com' '--mandir=/opt/alt/php74/usr/share/man' '--infodir=/opt/alt/php74/usr/share/info' '--cache-file=../config.cache' '--with-libdir=lib64' '--with-config-file-path=/opt/alt/php74/etc' '--with-config-file-scan-dir=/opt/alt/php74/link/conf' '--disable-debug' '--enable-calendar' '--enable-exif' '--enable-ftp' '--enable-huge-code-pages' '--enable-opcache' '--enable-shmop' '--enable-xml' '--with-bz2' '--with-freetype=/usr' '--with-gettext' '--with-gmp' '--with-iconv' '--with-jpeg=/usr' '--with-kerberos' '--with-layout=GNU' '--with-mhash' '--with-openssl-dir=/opt/alt/openssl11' '--with-openssl=/opt/alt/openssl11' '--with-password-argon2=/usr' '--with-pcre-jit' '--with-pcre-dir=/opt/alt/pcre2' '--enable-jit' '--with-pic' '--with-readline' '--with-webp=/opt/alt/libwebp' '--with-xpm=/usr' '--with-zlib' '--with-zlib-dir=/usr' '--without-gdbm' '--without-pear' '--enable-litespeed' '--enable-pcntl' '--without-mysqli' '--disable-mbstring' '--disable-bcmath' '--disable-dba' '--disable-dom' '--disable-fileinfo' '--disable-json' '--disable-intl' '--disable-pdo' '--disable-phar' '--disable-posix' '--disable-soap' '--disable-sockets' '--disable-sysvsem' '--disable-sysvshm' '--disable-sysvmsg' '--disable-xmlreader' '--disable-xmlwriter' '--without-zip' '--disable-gd' '--without-imap' '--without-xmlrpc' '--without-xsl' '--without-ldap' '--without-pgsql' '--without-snmp' '--without-sodium' '--without-tidy' '--without-enchant' '--without-pspell' '--without-unixODBC' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'target_alias=x86_64-redhat-linux-gnu' 'PKG_CONFIG_PATH=/opt/alt/curlssl11/usr/lib64/pkgconfig:/opt/alt/openssl11/lib64/pkgconfig:/opt/alt/libxml2/usr/lib64/pkgconfig:/opt/alt/sqlite/usr/lib64/pkgconfig:/opt/alt/libicu/usr/lib64/pkgconfig:/opt/alt/pcre2/usr/lib64/pkgconfig:/opt/alt/libgd/lib64/pkgconfig:/opt/alt/libzip/usr/lib64/pkgconfig:/opt/alt/krb5/usr/lib64/pkgconfig::/usr/lib64/pkgconfig:/usr/share/pkgconfig' 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -fno-strict-aliasing -Wno-pointer-sign' 'KERBEROS_CFLAGS=-I/usr/include' 'KERBEROS_LIBS=-L/usr/lib64' 'WEBP_LIBS=-L/opt/alt/libwebp/lib64 -Wl,-rpath=/opt/alt/libwebp/lib64' 'CXXFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic' 'SASL_CFLAGS=-I/usr/include' 'SASL_LIBS=-L/usr/lib64'
Server API LiteSpeed V8.0.1 Cloudlinux 1.3
Virtual Directory Support disabled
Configuration File (php.ini) Path /opt/alt/php74/etc
Loaded Configuration File /opt/alt/php74/etc/php.ini
Scan this dir for additional .ini files :/home/xxx/etc/php_settings/conf.d
Additional .ini files parsed /opt/alt/php74/link/conf/alt_php.ini, /home/xxx/etc/php_settings/conf.d/00-xxx.ini
PHP API 20190902
PHP Extension 20190902
Zend Extension 320190902
Zend Extension Build API320190902,NTS
PHP Extension Build API20190902,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support disabled
Registered PHP Streams https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3
Registered Stream Filters zlib.*, bzip2.*, convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v3.4.0, Copyright (c) Zend Technologies
with the ionCube PHP Loader + ionCube24 v11.0.1, Copyright (c) 2002-2022, by ionCube Ltd.
with Zend OPcache v7.4.32, Copyright (c), by Zend Technologies
apcu
APCu Support Enabled
Version 5.1.21
APCu Debugging Disabled
MMAP Support Enabled
MMAP File Mask no value
Serialization Support php
Build Date Sep 14 2022 15:18:24
Directive Local Value Master Value
apc.coredump_unmap Off Off
apc.enable_cli On On
apc.enabled On On
apc.entries_hint 4096 4096
apc.gc_ttl 3600 3600
apc.mmap_file_mask no value no value
apc.preload_path no value no value
apc.serializer php php
apc.shm_segments 1 1
apc.shm_size 32M 32M
apc.slam_defense Off Off
apc.smart 0 0
apc.ttl 0 0
apc.use_request_time Off Off
bcmath
BCMath support enabled
bcmath.scale 0 0
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.6, 6-Sept-2010
calendar
Calendar support enabled
Core
PHP Version 7.4.32
allow_url_fopen On On
allow_url_include Off Off
arg_separator.input & &
arg_separator.output & &
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset UTF-8 UTF-8
default_mimetype text/html text/html
disable_classes no value no value
disable_functions exec, shell_exec, system, dl, passthru, proc_open, proc_close, mail exec, shell_exec, system, dl, passthru, proc_open, proc_close, mail
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
enable_post_data_reading On On
error_append_string no value no value
error_log error_log error_log
error_prepend_string no value no value
error_reporting 24565 24565
expose_php Off Off
extension_dir /opt/alt/php74/usr/lib64/php/modules /opt/alt/php74/usr/lib64/php/modules
file_uploads On On
hard_timeout 2 2
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path . .
input_encoding no value no value
internal_encoding no value no value
log_errors Off Off
log_errors_max_len 1024 1024
mail.add_x_header On On
mail.force_extra_parameters no value no value
mail.log no value no value
max_execution_time 60 60
max_file_uploads 20 20
max_input_nesting_level 64 64
max_input_time 60 60
max_input_vars 5000 5000
memory_limit 512M 512M
open_basedir no value no value
output_buffering 4096 4096
output_encoding no value no value
output_handler no value no value
post_max_size 200M 200M
precision 14 14
realpath_cache_size 4096K 4096K
realpath_cache_ttl 120 120
register_argc_argv Off Off
report_memleaks On On
report_zend_debug On On
request_order no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sys_temp_dir no value no value
syslog.facility LOG_USER LOG_USER
syslog.filter no-ctrl no-ctrl
syslog.ident php php
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 200M 200M
upload_tmp_dir no value no value
user_dir no value no value
user_ini.cache_ttl 300 300
user_ini.filename .user.ini .user.ini
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
zend.assertions 1 1
zend.detect_unicode On On
zend.enable_gc On On
zend.exception_ignore_args Off Off
zend.multibyte Off Off
zend.script_encoding no value no value
zend.signal_check Off Off
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.71.0
Age 6
Features
AsynchDNS Yes
CharConv No
Debug No
GSS-Negotiate No
IDN No
IPv6 Yes
krb4 No
Largefile Yes
libz Yes
NTLM Yes
NTLMWB Yes
SPNEGO Yes
SSL Yes
SSPI No
TLS-SRP Yes
HTTP2 Yes
GSSAPI Yes
KERBEROS5 Yes
UNIX_SOCKETS Yes
PSL No
HTTPS_PROXY Yes
MULTI_SSL No
BROTLI No
Protocols dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smb, smbs, smtp, smtps, telnet, tftp
Host x86_64-redhat-linux-gnu
SSL Version OpenSSL/1.1.1d
ZLib Version 1.2.7
libSSH Version libssh2/1.8.0
curl.cainfo no value no value
date
date/time support enabled
timelib version 2018.04
"Olson" Timezone Database Version 2022.1
Timezone Database internal
Default timezone xxx/xxx
date.default_latitude ...
date.default_longitude ...
date.sunrise_zenith ...
date.sunset_zenith ...
date.timezone xxx/xxx xxx/xxx
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.9.7
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
Supported EXIF Version 0220
Supported filetypes JPEG, TIFF
Multibyte decoding support using mbstring enabled
Extended EXIF tag formats Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intel JIS JIS
exif.decode_jis_motorola JIS JIS
exif.decode_unicode_intel UCS-2LE UCS-2LE
exif.decode_unicode_motorola UCS-2BE UCS-2BE
exif.encode_jis no value no value
exif.encode_unicode ISO-8859-15 ISO-8859-15
fileinfo
fileinfo support enabled
libmagic 537
filter
Input Validation and Filtering enabled
filter.default unsafe_raw unsafe_raw
filter.default_flags no value no value
ftp
FTP support enabled
FTPS support enabled
gd
GD Support enabled
GD headers Version 2.2.5
GD library Version 2.2.5
FreeType Support enabled
FreeType Linkage with freetype
GIF Read Support enabled
GIF Create Support enabled
JPEG Support enabled
PNG Support enabled
WBMP Support enabled
XPM Support enabled
XBM Support enabled
WebP Support enabled
BMP Support enabled
TGA Read Support enabled
gd.jpeg_ignore_warning 1 1
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 6.0.0
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b crc32c fnv132 fnv1a32 fnv164 fnv1a64 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.17
iconv.input_encoding no value no value
iconv.internal_encoding no value no value
iconv.output_encoding no value no value
imagick
imagick module enabled
imagick module version 3.7.0
imagick classes Imagick, ImagickDraw, ImagickPixel, ImagickPixelIterator, ImagickKernel
Imagick compiled with ImageMagick version ImageMagick 7.1.0-20 Q16-HDRI x86_64 2022-01-22 https://imagemagick.org
Imagick using ImageMagick library version ImageMagick 7.1.0-20 Q16-HDRI x86_64 2022-01-22 https://imagemagick.org
ImageMagick copyright (C) 1999-2021 ImageMagick Studio LLC
ImageMagick release date 2022-01-22
ImageMagick number of supported formats: 260
ImageMagick supported formats 3FR, 3G2, 3GP, AAI, AI, APNG, ART, ARW, ASHLAR, AVI, AVIF, AVS, BGR, BGRA, BGRO, BIE, BMP, BMP2, BMP3, BRF, CAL, CALS, CANVAS, CAPTION, CIN, CIP, CLIP, CMYK, CMYKA, CR2, CR3, CRW, CUBE, CUR, CUT, DATA, DCM, DCR, DCRAW, DCX, DDS, DFONT, DNG, DOT, DPX, DXT1, DXT5, EPDF, EPI, EPS, EPS2, EPS3, EPSF, EPSI, EPT, EPT2, EPT3, ERF, EXR, FARBFELD, FAX, FF, FILE, FITS, FL32, FLV, FRACTAL, FTP, FTS, FTXT, G3, G4, GIF, GIF87, GRADIENT, GRAY, GRAYA, GROUP4, GV, HALD, HDR, HEIC, HEIF, HISTOGRAM, HRZ, HTM, HTML, HTTP, HTTPS, ICB, ICO, ICON, IIQ, INFO, INLINE, IPL, ISOBRL, ISOBRL6, J2C, J2K, JBG, JBIG, JNG, JNX, JP2, JPC, JPE, JPEG, JPG, JPM, JPS, JPT, JSON, K25, KDC, KERNEL, LABEL, M2V, M4V, MAC, MAP, MASK, MAT, MATTE, MEF, MIFF, MKV, MNG, MONO, MOV, MP4, MPC, MPEG, MPG, MRW, MSL, MSVG, MTV, MVG, NEF, NRW, NULL, ORA, ORF, OTB, OTF, PAL, PALM, PAM, PANGO, PATTERN, PBM, PCD, PCDS, PCL, PCT, PCX, PDB, PDF, PDFA, PEF, PES, PFA, PFB, PFM, PGM, PGX, PHM, PICON, PICT, PIX, PJPEG, PLASMA, PNG, PNG00, PNG24, PNG32, PNG48, PNG64, PNG8, PNM, POCKETMOD, PPM, PS, PS2, PS3, PSB, PSD, PTIF, PWP, QOI, RADIAL-GRADIENT, RAF, RAS, RAW, RGB, RGB565, RGBA, RGBO, RGF, RLA, RLE, RMF, RSVG, RW2, SCR, SCT, SFW, SGI, SHTML, SIX, SIXEL, SPARSE-COLOR, SR2, SRF, STEGANO, SUN, SVG, SVGZ, TEXT, TGA, THUMBNAIL, TIFF, TIFF64, TILE, TIM, TM2, TTC, TTF, TXT, UBRL, UBRL6, UIL, UYVY, VDA, VICAR, VID, VIFF, VIPS, VST, WBMP, WEBM, WEBP, WMF, WMV, WMZ, WPG, X, X3F, XBM, XC, XCF, XPM, XPS, XV, XWD, YAML, YCbCr, YCbCrA, YUV
imagick.allow_zero_dimension_images 0 0
imagick.locale_fix 0 0
imagick.progress_monitor 0 0
imagick.set_single_thread 1 1
imagick.shutdown_sleep_count 10 10
imagick.skip_version_check 0 0
imap
IMAP c-Client Version 2007f
SSL Support enabled
Kerberos Support enabled
imap.enable_insecure_rsh Off Off
intl
Internationalization support enabled
ICU version 63.1
ICU Data version 63.1
ICU TZData version 2018e
ICU Unicode version 11.0
intl.default_locale no value no value
intl.error_level 0 0
intl.use_exceptions 0 0
ionCube Loader
ionCube logo ionCube24 logo
ionCube Loader developed by ionCube Ltd.
Visit ioncube.com for latest Loaders and support.
This Loader also includes features for real-time error reporting and malware protection. Visit ioncube24.com for more details.
Loader version 11.0.1
ionCube24 features unconfigured
ic24.api.log_msg_errors 0 0
ic24.api.max_timeout 7 7
ic24.api_access_key ******** ********
ic24.api_check_ip 1 1
ic24.enable 0 0
ic24.home_dir no value no value
ic24.phperr.enable auto auto
ic24.phperr.ignore 0 0
ic24.sec.block_stdin 1 1
ic24.sec.block_uploaded_files 1 1
ic24.sec.enable auto auto
ic24.sec.exclusion_key ******** ********
ic24.sec.initial_action block block
ic24.sec.initial_cache_all 1 1
ic24.sec.initial_notify always always
ic24.sec.initial_state 1 1
ic24.sec.stop_on_error 1 1
ic24.sec.trusted_include_paths ******** ********
ic24.slt 7 7
ic24.update_domains_retry_interval 30 30
ioncube.loader.encoded_paths no value no value
json
json support enabled
ldap
LDAP Support enabled
Total Links 0/unlimited
API Version 3001
Vendor Name OpenLDAP
Vendor Version 20446
SASL Support Enabled
ldap.max_links Unlimited Unlimited
libxml
libXML support active
libXML Compiled Version 2.9.7
libXML Loaded Version 20907
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation disabled
libmbfl version 1.3.2
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 6.8.2
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input no value no value
mbstring.http_output no value no value
mbstring.http_output_conv_mimetypes ^(text/|application/xhtml\+xml) ^(text/|application/xhtml\+xml)
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.regex_retry_limit 1000000 1000000
mbstring.regex_stack_limit 100000 100000
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mysqli
MysqlI Support enabled
Client API library version mysqlnd 7.4.32
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infile Off Off
mysqli.allow_persistent On On
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.max_persistent Unlimited Unlimited
mysqli.reconnect Off Off
mysqli.rollback_on_cached_plink Off Off
mysqlnd
mysqlnd enabled
Version mysqlnd 7.4.32
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 86400
Collecting statistics No
Collecting memory statistics No
Tracing n/a
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password
API Extensions mysqli,pdo_mysql
OAuth
OAuth support enabled
PLAINTEXT support enabled
RSA-SHA1 support enabled
HMAC-SHA1 support enabled
Request engine support php_streams, curl
version 2.0.4
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 1.1.1d 10 Sep 2019
OpenSSL Header Version OpenSSL 1.1.1p 21 Jun 2022
Openssl default config /opt/alt/openssl11/etc/pki/tls/openssl.cnf
openssl.cafile no value no value
openssl.capath no value no value
pcntl
pcntl support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 10.35 2020-05-09
PCRE Unicode Version 13.0.0
PCRE JIT Support enabled
PCRE JIT Target x86 64bit (little endian + unaligned)
pcre.backtrack_limit 1000000 1000000
pcre.jit 1 1
pcre.recursion_limit 100000 100000
PDO
PDO support enabled
PDO drivers mysql, sqlite
pdo_mysql
PDO Driver for MySQL enabled
Client API version mysqlnd 7.4.32
pdo_mysql.default_socket /tmp/mysql.sock /tmp/mysql.sock
pdo_sqlite
PDO Driver for SQLite 3.x enabled
SQLite Library 3.26.0
Phar
Phar: PHP Archive support enabled
Phar API version 1.1.1
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list no value no value
phar.readonly On On
phar.require_hash On On
posix
POSIX support enabled
pspell
PSpell Support enabled
readline
Readline Support enabled
Readline library 6.2
cli.pager no value no value
cli.prompt \b \> \b \>
Reflection
Reflection enabled
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php_serialize php php_binary
session.auto_start Off Off
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_httponly no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_samesite no value no value
session.cookie_secure 0 0
session.gc_divisor 100 100
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.lazy_write On On
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /tmp /tmp
session.serialize_handler php php
session.sid_bits_per_character 4 4
session.sid_length 32 32
session.upload_progress.cleanup On On
session.upload_progress.enabled On On
session.upload_progress.freq 1% 1%
session.upload_progress.min_freq 1 1
session.upload_progress.name PHP_SESSION_UPLOAD_PROGRESS PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix upload_progress_ upload_progress_
session.use_cookies 1 1
session.use_only_cookies 1 1
session.use_strict_mode 0 0
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
SimpleXML support enabled
Schema support enabled
soap
Soap Client enabled
Soap Server enabled
soap.wsdl_cache 1 1
soap.wsdl_cache_dir /tmp /tmp
soap.wsdl_cache_enabled 1 1
soap.wsdl_cache_limit 5 5
soap.wsdl_cache_ttl 86400 86400
sockets
Sockets Support enabled
sodium
sodium support enabled
libsodium headers version 1.0.18
libsodium library version 1.0.18
SPL
SPL support enabled
Interfaces OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
sqlite3
SQLite3 support enabled
sqlite3.defensive 1 1
sqlite3.extension_dir no value no value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.exception 0 0
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
session.trans_sid_hosts no value no value
session.trans_sid_tags a=href,area=href,frame=src,form= a=href,area=href,frame=src,form=
unserialize_max_depth 4096 4096
url_rewriter.hosts no value no value
url_rewriter.tags a=href,area=href,frame=src,input=src,form=,fieldset= a=href,area=href,frame=src,input=src,form=,fieldset=
user_agent no value no value
tidy
Tidy support enabled
libTidy Version 5.4.0
libTidy Release 2017/03/01
tidy.clean_output no value no value
tidy.default_config no value no value
tokenizer
Tokenizer Support enabled
vips
vips property value
Vips headers version 8.5.6
Vips library version 8.5.6
Vips ABI version 49.5.7
Major version 8
Minor version 5
Micro version 6
SIMD support with liborc yes
JPEG support yes
PNG support yes
TIFF support yes
GIF support yes
OpenEXR support yes
load OpenSlide yes
load Matlab yes
load PDF yes
load SVG yes
FITS support yes
WebP support yes
load with libMagick yes
Text rendering support yes
ICC profile support with lcms yes
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.9.7
xmlreader
XMLReader enabled
xmlrpc
core library version xmlrpc-epi v. 0.51
author Dan Libby
homepage http://xmlrpc-epi.sourceforge.net
open sourced by Epinions.com
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.28
libxslt compiled against libxml Version 2.9.1
EXSLT enabled
libexslt Version 1.1.28
Zend OPcache
Opcode Caching Up and Running
Optimization Enabled
SHM Cache Enabled
File Cache Disabled
Startup OK
Shared memory model mmap
Cache hits 3619721
Cache misses 1385
Used memory 30166704
Free memory 104050224
Wasted memory 800
Interned Strings Used memory 3908016
Interned Strings Free memory 2382992
Cached scripts 1384
Cached keys 2644
Max keys 16229
OOM restarts 0
Hash keys restarts 0
Manual restarts 0
opcache.blacklist_filename no value no value
opcache.consistency_checks 0 0
opcache.dups_fix Off Off
opcache.enable On On
opcache.enable_cli Off Off
opcache.enable_file_override Off Off
opcache.error_log no value no value
opcache.file_cache no value no value
opcache.file_cache_consistency_checks On On
opcache.file_cache_only Off Off
opcache.file_update_protection 2 2
opcache.force_restart_timeout 180 180
opcache.huge_code_pages Off Off
opcache.interned_strings_buffer 8 8
opcache.lockfile_path /tmp /tmp
opcache.log_verbosity_level 1 1
opcache.max_accelerated_files 10000 10000
opcache.max_file_size 0 0
opcache.max_wasted_percentage 5 5
opcache.memory_consumption 128 128
opcache.opt_debug_level 0 0
opcache.optimization_level 0x7FFEBFFF 0x7FFEBFFF
opcache.preferred_memory_model no value no value
opcache.preload no value no value
opcache.preload_user no value no value
opcache.protect_memory Off Off
opcache.restrict_api no value no value
opcache.revalidate_freq 2 2
opcache.revalidate_path Off Off
opcache.save_comments On On
opcache.use_cwd On On
opcache.validate_permission Off Off
opcache.validate_root Off Off
opcache.validate_timestamps On On
zip
Zip enabled
Zip version 1.15.6
Libzip headers version 1.3.2
Libzip library version 1.3.2
zlib
ZLib Support enabled
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.7
Linked Version 1.2.7
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
litespeed
Environment
Variable Value
LSPHP_ENABLE_USER_INI on
PHP_INI_SCAN_DIR :/home/xxx/etc/php_settings/conf.d
PATH /usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
VIPSHOME /usr
PHP Variables
Variable Value
$_SERVER['LSPHP_ENABLE_USER_INI'] on
$_SERVER['PHP_INI_SCAN_DIR'] :/home/xxx/etc/php_settings/conf.d
$_SERVER['PATH'] /usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
$_SERVER['VIPSHOME'] /usr
$_SERVER['HTTP_ACCEPT'] text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8
$_SERVER['HTTP_ACCEPT_ENCODING'] gzip, deflate
$_SERVER['HTTP_ACCEPT_LANGUAGE'] de,en-US;q=0.7,en;q=0.3
$_SERVER['HTTP_CONNECTION'] keep-alive
$_SERVER['HTTP_HOST'] lab805.com
$_SERVER['HTTP_USER_AGENT'] Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:106.0) Gecko/20100101 Firefox/106.0
$_SERVER['HTTP_DNT'] 1
$_SERVER['HTTP_UPGRADE_INSECURE_REQUESTS'] 1
$_SERVER['DOCUMENT_ROOT'] /home/xxx/public_html/xxx.xxx.site
$_SERVER['REMOTE_ADDR'] 84.75.64.225
$_SERVER['REMOTE_PORT'] 58162
$_SERVER['SERVER_ADDR'] 149.126.4.111
$_SERVER['SERVER_NAME'] lab805.com
$_SERVER['SERVER_ADMIN'] webmaster@...
$_SERVER['SERVER_PORT'] 80
$_SERVER['REQUEST_SCHEME'] http
$_SERVER['REQUEST_URI'] /index.php
$_SERVER['SCRIPT_FILENAME'] /home/xxx/public_html/xxx.xxx.site/index.php
$_SERVER['QUERY_STRING'] no value
$_SERVER['SCRIPT_URI'] http://xxx.com/index.php
$_SERVER['SCRIPT_URL'] /index.php
$_SERVER['SCRIPT_NAME'] /index.php
$_SERVER['SERVER_PROTOCOL'] HTTP/1.1
$_SERVER['SERVER_SOFTWARE'] LiteSpeed
$_SERVER['REQUEST_METHOD'] GET
$_SERVER['X-LSCACHE'] on
$_SERVER['PHP_SELF'] /index.php
$_SERVER['REQUEST_TIME_FLOAT'] 1667419023.1302
$_SERVER['REQUEST_TIME'] 1667419023
$_ENV['LSPHP_ENABLE_USER_INI'] on
$_ENV['PHP_INI_SCAN_DIR'] :/home/xxx/etc/php_settings/conf.d
$_ENV['PATH'] /usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
$_ENV['VIPSHOME'] /usr
