You need to add some error handling there then. Depending on the directory you redirected to which was in my sample āpath/path2/subpathā, there may or may not be any collections (sub-folders).
I donāt know if it is possible to download the entire directory at once using this library. You could attempt it though. FolderFiles is perhaps a rather non-fitting name, as you get āitemsā back (which is either a folder or file). Just make sure you select a folder item and see if you can download it.
What kind of error handling do you mean? The class you wrote to me a few days back couls be edited to IDisposable. Then it requires the function Dispose inside the class. But here is the question - what am I disposing exactly? The called class itself or what?
After thia problem is solved, are you suggesting I should download folderās files one by one? Wouldnāt it be much less complicated if I just uploaded .rar file instead of the folder. Would it even count as file?
Here is the problem:
āPropfindResponseā does not contain a definition for āFirstOrDefaultā and no accessible extension method āFirstOrDefaultā accepting a first argument of type āPropfindResponseā could be found (are you missing a using directive or an assembly reference?)
The code for downloading a file inside my class is this (error: FirstOrDefault):
public async Task<WebDavStreamResponse> Download(string url)
// Retrieve list of items in 'Test' folder
var folderFiles = await GetItemsAsyncCloudItem(url);
// Find first file in 'Test' folder
var folderFile = folderFiles.FirstOrDefault(f => f.IsCollection == false);
var tempFileName = Path.GetTempFileName();
// Download item into a temporary file
using (var tempFile = File.OpenWrite(tempFileName))
using (var stream = await _webDavClient.GetProcessedFile(folderFile.Href))
return await stream.CopyToAsync(tempFile);
I used this function in my class to await the file
The library in place responds in generic āwebdav itemsā, this can be files and/or sub-folders of the given path. In case the path only contain sub-folders, the property āIsCollectionā will always be true for all the items, if there are any files within the collection they will have IsCollection = false.
The error you are referring to is probably that you are missing out on using System.Linq;, you need that reference.
You are disposing the streams in place, one for the filestream and one for downloading it in-memory. I do not recommend disposing the HttpClient itself.
I donāt know if you can directly download the folder as a .zip file (or .rar), probably not, you can always test it out.
So what you basically mean is that every sub-folder in my folder (ex. main folder where everything is located) will trigger IsCollection = true ? So I thought maybe I could tell the code the home location of all my sub-folders and check for IsCollection = true and download the required sub-folder according to its name. Or will it just download the sub-folderās contents as you mentioned?
The problem is, I have been using Linq and checked the projectās references and, as it turns out, System.Linq.dll is checked. Is there any way to fix that error or do you want me to take a screenshot of references?
This means I just need to set the stream variable for downloading the files to NULL or just somehow reset it?
Try thisā¦ did not run it, but does not give any compile errors.
public async Task Download(string url)
var folderFile = folderFiles.Resources.FirstOrDefault(f => f.IsCollection == false);
using (var stream = await _webDavClient.GetProcessedFile(folderFile.Uri))
await stream.Stream.CopyToAsync(tempFile);
Note, I modified it to resources, checked also WebDavStreamResponse, it does not have any CopyToAsync.
Yes, I used this and FirstOrDefault function finally gives no errors and seems to be working. But thereās the other problem Iāve been talking about - disposing. You see, I still get the error.
WebDavStreamResponseā: type used in a using statement must be implicitly convertible to āSystem.IDisposableā.
Do you think changing the library to the one you just suggested me might do the trick?
It is trying to download to temporary file in Temp folder, but somehow the 2,6GB file is downloaded immediately and if I check the fileās size, I have 0Bā¦ I think thereās problem somewhereā¦ Is it because I am trying to download a folder instead of a file?
Found an easier solution to circumvent this error:
ArgumentException: Only HTTP/1.0 and HTTP/1.1 version requests are currently supported.
Add the HTTP Version explicit:
System.Version version = System.Version.Parse("1.0");
webDavSession.HttpVersion = version;
Code:
// Specify the user credentials and use it to create a WebDavSession instance.
var credentials = new NetworkCredential("username", "pass");
var webDavSession = new
WebDavSession(@"https://cd.wedos.com/remote.php/dav/files/username/", credentials);
var items = await webDavSession.ListAsync(@"Talk/");
sorry to disturb you i have facing same issue,
so can you please help me or share code with me if possible.
i am also unable to upload file from my PC to Nextcloud using asp.net c#.
plz plz plz help me.
