I discovered a conflict between Nextcloud and ownCloud nautilus integration, which I first interpreted as a broken owncloud package.
I have both Nextcloud and ownCloud desktop app installed on my Ubuntu 20.04 system, both with several accounts.
nextcloud-desktop: 3.3.0-20210804.143427.acf3bf095-1.0~focal1, just updated to 3.3.1-20210814.134354.cd934ba80-1.0~focal1, which does not change anything to the problem
owncloud-client : 2.8.2+oc-4246
The nautilus integration tool which works are owncloud-client-nautilus and nautilus-nextcloud, but I cannot use both. They mess up and I end up having duplicates nextcloud entry in contextual menus on nextcloud folders and nothing for owncloud.
Nextcloud nextcloud-desktop: 3.3.0-20210804.143427.acf3bf095-1.0~focal1
Operating system : Ubuntu 20.04)_:
nautilus-nextcloud conflicts with owncloud-client-nautilus
Is this the first time you’ve seen this error? (N):
- Install owncloud and nextcloud
- Install also nautilus integration
- Try to get contextual menus from Nextcloud and ownCloud local folders.
- No owncloud menu on local owncloud folders or files, duplicate Nextcloud entry on Nextcloud local folders or files
