Official documentation (searchable and regularly updated)
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
31.0.4.1
Debian GNU/Linux 12 (bookworm)
Apache/2.4.62 (Debian)
- PHP version (e.g, 8.3):
8.4.6
Yes
Bare Metal
No
I tried to set config.php for logging to use systemd. But doing this and then connecting Nextcloud fails, probably because php-systemd is missing. But this is very old and only to install from source. Not trusty and not helpful. Switched back to use file.
So using systemd with these instructions is not feasible.
If somebody knows how to achieve, would be great to tell me.
Switch logging to systemd following instructions
Connect Nextcloud
PASTE
PASTE HERE
PASTE HERE
Use the
preformatted textformatting option in the editor for all log entries and configuration output. -
If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
