I want to deploy a ONE Collabora CODE on a new VPS but it is to serve TWO nextcloud servers
Is this possible, can someone assist me or direct me
Thank you
Thank you
I really dont know if it that can be done!
You could use docker, and run 2 containers, one for each NC instance, then use nginx to proxy them. Each one on their own sub.domain.tld and running for the specified nc-instance.
Yeah, you can do it.
docker run -t -d -p 127.0.0.1:9980:9980 -e "domain=cloud1\\.domain\\.com|cloud2\\.domain\\.com|cloud3\\.domain\\.com|cloud4\\.domain\\.com|cloud4\\.domain\\.com" -e "username=admin" -e "password=very-secr3t" --restart always --cap-add MKNOD collabora/code
Try something like this.
But be aware that CODE has a limitation of 10 open documents, 20 connections.
So you might donโt wanna exceed that limit or cloud host to connect to.
I am doing this, and it works, however, as shown in my own recent post, I am having issues when one User is connected to Nextcloud Instance 1 and one user is connected to Instance 2. They are unable to collaborate on the same document unless they are both connected to the same instance. Maybe youโll be able to figure it out?
