I installed a NC (version 20.0.5) on my domain www.mydomain.de and also on my local computer and installed Collabora Built-in CODE Server and Collabora online. On my local installation it works fine and I can edit office files but if I activate Collabora Online on my domain installation NC becomes extremly slow, any action takes several minutes. It is impossible to work with NC in a normal manner.
Can someone help?
Sorry.
Was a little in a hurry when i answered to the thread.
The github issue is this one:
Unfortunately there is no solution so far and the last post is more than a year old.
In my case it is really easy to reproduce.
Install the code server, install collabora and the external access instantly slow down to 2 min loading time. Remove the collabora stuff and normal loading times. With the lokal ip address everything works fine.
As mentioned my ncp instance is behind a ngnix proxy.
