jweez
November 6, 2016, 5:30pm
#1
Im trying to setup callabora and have problem. Everything seems to work but Collabora cant open any docuemt.
I get this in my docker log:
wsd-00024-0027 0:01:49.740961 [ client_ws_0001 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:01:49.752013 [ client_ws_0001 ] ERR Error in client request handler: Invalid access
wsd-00024-0026 0:01:49.834212 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
wsd-00024-0026 0:02:15.903246 [ client_ws_0002 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0026 0:02:15.903819 [ client_ws_0002 ] ERR Error in client request handler: Invalid access
wsd-00024-0027 0:02:47.577852 [ client_ws_0003 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:02:47.578388 [ client_ws_0003 ] ERR Error in client request handler: Invalid access
wsd-00024-0027 0:24:42.745170 [ client_ws_0004 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:24:42.745715 [ client_ws_0004 ] ERR Error in client request handler: Invalid access
wsd-00024-0026 0:24:42.762066 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
wsd-00024-0027 0:24:59.958119 [ client_ws_0005 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:24:59.958455 [ client_ws_0005 ] ERR Error in client request handler: Invalid access
wsd-00024-0026 0:24:59.972963 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
wsd-00024-0027 0:26:19.156723 [ client_ws_0006 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:26:19.156990 [ client_ws_0006 ] ERR Error in client request handler: Invalid access
wsd-00024-0026 0:26:19.178422 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
wsd-00024-0026 0:28:53.885689 [ client_ws_0007 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0026 0:28:53.885964 [ client_ws_0007 ] ERR Error in client request handler: Invalid access
wsd-00024-0027 0:28:56.067936 [ client_ws_0008 ] ERR Missing JSON property: 'BaseFileName’
wsd-00024-0027 0:28:56.068392 [ client_ws_0008 ] ERR Error in client request handler: Invalid access
Any ide?
Lars_M
November 7, 2016, 7:55am
#2
have the same issue, but other logentrys
kit-00041-0041 0:00:08.164746 [ loolkit ] ERR symlink("../lo","/opt/lool/child-roots/41/opt/collaboraoffice5.1") failed (errno: File exists)
kit-00042-0042 0:00:08.164909 [ loolkit ] ERR symlink("../lo","/opt/lool/child-roots/42/opt/collaboraoffice5.1") failed (errno: File exists)
mit-00041-0041 0:00:08.170753 [ loolkit ] ERR Poco Exception: Exception: symlink() failed310mkit-00042-0042 0:00:08.170761 [ loolkit ] ERR Poco Exception: Exception: symlink() failed
kit-00048-0048 0:00:14.962943 [ loolkit ] ERR symlink("../lo","/opt/lool/child-roots/48/opt/collaboraoffice5.1") failed (errno: File exists)
kit-00048-0048 0:00:14.963106 [ loolkit ] ERR Poco Exception: Exception: symlink() failed
wsd-00024-1549 0:30:32.518030 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
kennyMC
November 8, 2016, 9:27am
#3
me 2:
wsd-00025-0026 0:01:23.375137 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
do you guys use nginx or apache?
I use Nginx, got the same issues
Lars_M
November 8, 2016, 7:51pm
#5
Apache but Ngnix as Proxy
kennyMC
November 9, 2016, 9:42am
#6
i also use nginx, maybe thats a part of the problem?!
Lars_M
November 9, 2016, 11:50am
#7
good question. I try it out.
Lars_M
November 9, 2016, 12:15pm
#8
my docker logs for this collabora container shows this issue. wsd-00024-0290 26:51:31.509699 [ client_req_hdl ] ERR FileServerRequestHandler: File not found: /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness/images/ui-bg_highlight-soft_100_eeeeee_1x100.png
find / -name ui-lightness /usr/share/loolwsd/loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness /usr/share/loolwsd/loleaflet/dist/node_modules/jquery-ui/themes/themes/ui-lightness /usr/share/loolwsd/loleaflet/dist/jqueryui/1.11.1/themes/ui-lightness
I checked it and the complete path /usr/share/loolwsd//loleaflet/dist/node_modules/jquery-ui/themes/ui-lightness don’t exist. anyone with the same issue? maybe an error why collabora won’t work correct.
kennyMC
November 17, 2016, 9:43am
#9
has anyone found a solution?
Lars_M
November 17, 2016, 11:05am
#10
create an user with group and password and run these command:
docker pull collabora/code
docker run -t -d -p 127.0.0.1:9980:9980 -e 'domain=cloud\\.nextcloud\\.com' -e 'username=admin' -e 'password=123456' --restart always --cap-add MKNOD collabora/code
that work for me.
kennyMC
November 17, 2016, 2:41pm
#11
thx for your answer. but i still have the same error.
kennyMC
November 21, 2016, 12:48pm
#12
finally i found a solution. just disable your firewall service and your docker service, then start docker service first and after that start your firewall service. that did the trick for me!
Just on the off-chance it helps, I edited your post title to provide some context.
