Hello, I had collabora working properly, but didn’t use it for a while, did an upgrade, some nginx updates and then I started having issues with it. The current behavior is that any document I open will open a very small frame in the corner of the browser and I can see that that’s the collabora running in there, but can’t get it full screen. in the Browser console I can see the following error being displayed:Blocked autofocusing on a form control in a cross-origin subframe.
I also tried to connect to a demo collabora server and had the exact same behaviour, so I would rule out the collabora installation issues.
My Current setup is:
Nextcloud 19.1 FPM docker,
MariaDB
Nginx.
My Nginx config for nextcloud is:
Nginx.conf
upstream php-handler {
server core_nextcloud:9000;
server {
error_log /opt/logs/ngingx.nextcloud.error.log debug;
access_log /opt/logs/nginx.nextcloud.access.log;
listen 443 ssl http2;
server_name www.nextcloud.mydomain.com nextcloud.mydomain.com;
ssl_certificate /etc/letsencrypt/live/nextcloud.mydomain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/nextcloud.mydomain.com/privkey.pem;
# Improve HTTPS performance with session resumption
ssl_session_cache shared:SSL:10m;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/dhparam4096.pem;
# Enable OCSP stapling
# ref. http://blog.mozilla.org/security/2013/07/29/ocsp-stapling-in-firefox
ssl_stapling on;
ssl_stapling_verify on;
ssl_trusted_certificate /etc/letsencrypt/live/nextcloud.mydomain.com/fullchain.pem;
#resolver 1.1.1.1 1.0.0.1 [2606:4700:4700::1111] [2606:4700:4700::1001] valid=300s; # Cloudflare
#resolver_timeout 5s;
# RFC-7919 recommended: https://wiki.mozilla.org/Security/Server_Side_TLS#ffdhe4096
# ssl_dhparam /etc/ssl/ffdhe4096.pem;
ssl_ecdh_curve secp521r1:secp384r1;
# Aditional Security Headers
# ref: https://developer.mozilla.org/en-US/docs/Security/HTTP_Strict_Transport_Security
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
#ssl_stapling on;
#ssl_stapling_verify on;
#ssl_trusted_certificate /etc/letsencrypt/live/nextcloud.mydomain.com/fullchain.pem;
ref: https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/X-Frame-Options
#add_header X-Frame-Options DENY always;
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /var/www/html;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
# The following rule is only needed for the Social app.
#rewrite ^/.well-known/webfinger /public.php?service=webfinger last;
return 301 $scheme://$host:$server_port/remote.php/dav;
# set max upload size
client_max_body_size 10G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
#pagespeed off;
location / {
rewrite ^ /index.php;
location ~ ^\/(?:build|tests|config|lib|3rdparty|templates|data)\/ {
deny all;
location ~ ^\/(?:\.|autotest|occ|issue|indie|db_|console) {
deny all;
location ~ ^\/(?:index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+)\.php(?:$|\/) {
fastcgi_split_path_info ^(.+?\.php)(\/.*|)$;
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
# Avoid sending the security headers twice
# Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^\/(?:updater|oc[ms]-provider)(?:$|\/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js, css and map files
location ~ \.(?:css|js|woff2?|svg|gif|map)$ {
add_header Cache-Control "public, max-age=15778463";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# Before enabling Strict-Transport-Security headers please read into
# this topic first.
#add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
# could take several months.
access_log off;
location ~ \.(?:png|html|ttf|ico|jpg|jpeg|bcmap|mp4|webm)$ {
# Optional: Don't log access to other assets
access_log off;
Did anyone else experience this? Would really appreciate any input or any ideas as to where to fix this…
My best guess is that i’ve done something wrong in nginx config, as I ended up trying to do a clean install of nextcloud - but had the same issue.
Thank you in advance for the involvement
SOLVED:
For anyone that might come across this… this was a very stupid mistake, I was migrating the nextcloud instance to a different path on my server, but I didn’t remove the initial /var/www/html mapping to docker’s nginx instance… so… nginx was accessing the old nextcloud 18 instance of /var/www/html while nextcloud was happily upgraded and running nc19 in a totally different location.
