Hey everyone,
I’ve set up a Collabora Online Server a few days ago and it’s working. But when I try to access the Server via the Nextcloud Collabora Online App it gives me the following error messages:
Internal Server Error
The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
So I’ve read the log and heres what the log says:
GuzzleHttp\Exception\RequestException: cURL error 60: SSL certificate problem: self signed certificate
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 103: GuzzleHttp\Exception\RequestException wrapException(Object(GuzzleHttp\Message\Request), Object(GuzzleHttp\Ring\Exception\RingException))
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 132: GuzzleHttp\RequestFsm->__invoke(Object(GuzzleHttp\Transaction))
- /var/www/nextcloud/3rdparty/react/promise/src/FulfilledPromise.php - line 25: GuzzleHttp\RequestFsm->GuzzleHttp{closure}(*** sensitive parameters replaced ***)
- /var/www/nextcloud/3rdparty/guzzlehttp/ringphp/src/Future/CompletedFutureValue.php - line 55: React\Promise\FulfilledPromise->then(Object(Closure), NULL, NULL)
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Message/FutureResponse.php - line 43: GuzzleHttp\Ring\Future\CompletedFutureValue->then(Object(Closure), NULL, NULL)
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RequestFsm.php - line 134: GuzzleHttp\Message\FutureResponse proxy(Object(GuzzleHttp\Ring\Future\CompletedFutureArray), Object(Closure))
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php - line 165: GuzzleHttp\RequestFsm->__invoke(Object(GuzzleHttp\Transaction))
- /var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php - line 125: GuzzleHttp\Client->send(Object(GuzzleHttp\Message\Request))
- /var/www/nextcloud/lib/private/Http/Client/Client.php - line 138: GuzzleHttp\Client->get(’’, Array)
- /var/www/nextcloud/apps/richdocuments/lib/WOPI/DiscoveryManager.php - line 84: OC\Http\Client\Client->get(’’)
- /var/www/nextcloud/apps/richdocuments/lib/WOPI/Parser.php - line 41: OCA\Richdocuments\WOPI\DiscoveryManager->get()
- /var/www/nextcloud/apps/richdocuments/lib/TokenManager.php - line 122: OCA\Richdocuments\WOPI\Parser->getUrlSrc(‘application/vnd…’)
- /var/www/nextcloud/apps/richdocuments/lib/Controller/DocumentController.php - line 168: OCA\Richdocuments\TokenManager->getToken(*** sensitive parameters replaced ***)
- [internal function] OCA\Richdocuments\Controller\DocumentController->index(‘498’)
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 161: call_user_func_array(Array, Array)
- /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 91: OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Richdocuments\Controller\DocumentController), ‘index’)
- /var/www/nextcloud/lib/private/AppFramework/App.php - line 115: OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Richdocuments\Controller\DocumentController), ‘index’)
- /var/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47: OC\AppFramework\App main(‘OCA\Richdocumen…’, ‘index’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array)
- [internal function] OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)
- /var/www/nextcloud/lib/private/Route/Router.php - line 297: call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)
- /var/www/nextcloud/lib/base.php - line 998: OC\Route\Router->match(’/apps/richdocum…’)
- /var/www/nextcloud/index.php - line 37: OC handleRequest()
- {main}
I’ve tried every single option but nothing helps.
Every help is appreciated.
