Hi is there a possibility to install Collabora on a raspi zero? The image doesn’t work on arm I think. Is there a arm image anywhere? The problem is that I can’t install Collabora on my Nextcloud machine (Banana Pi) because it uses an old kernel. So I must use an other machine. I have a Pi zero which is running 24/7.
I have the same request of having a Collabora available for arm (for my Raspberry Pi 3) !
Thanks !
