Collabora not trust CA
I had a non-docker server with nextcloud+onlyoffice.
I’m now migrating to collabora.
I have an internal CA what generate the certs. When I go to port 9980 via browser it says “ok”. But when I whant to edit a document from Nextcloud I got this in journalctl:
may 11 13:41:23 nextclout-test loolwsd[2615]: wsd-02615-02622 2020-05-11 16:41:23.165295 [ websrv_poll ] ERR  Socket #22 SSL BIO error: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca (0: Success)| ./net/SslSocket.hpp:29
may 11 13:41:23 nextclout-test loolwsd[2615]: wsd-02615-02622 2020-05-11 16:41:23.165504 [ websrv_poll ] ERR  Error while handling poll for socket #22 in websrv_poll: error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca| net/Socket.cpp:308
I already added the CA with “update-ca-trust” command.
What can I do to fix this?
Thanks.
You can switch off certificate checks in the Collabora-Settings. And if you are using a proxy, be sure to follow the official instructions: Collabora Online Office – Nextcloud .
