I used letsencrypt certbot:
jason@linuxpd2:~$ sudo certbot --apache
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator apache, Installer apache
Which names would you like to activate HTTPS for?
1: linuxpd2.my_dyanamic_dns_domain.org
2: officelinuxpd2.my_dyanamic_dns_domain.org
Select the appropriate numbers separated by commas and/or spaces, or leave input
blank to select all options shown (Enter âcâ to cancel):
You have an existing certificate that contains a portion of the domains you
requested (ref: /etc/letsencrypt/renewal/officelinuxpd2.my_dyanamic_dns_domain.org.conf)
It contains these names: officelinuxpd2.my_dyanamic_dns_domain.org
You requested these names for the new certificate: linuxpd2.my_dyanamic_dns_domain.org,
Do you want to expand and replace this existing certificate with the new
certificate?
(E)xpand/©ancel: E
Renewing an existing certificate
Performing the following challenges:
http-01 challenge for linuxpd2.my_dyanamic_dns_domain.org
http-01 challenge for officelinuxpd2.my_dyanamic_dns_domain.org
Waiting for verificationâŠ
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
Please choose whether or not to redirect HTTP traffic to HTTPS, removing HTTP access.
1: No redirect - Make no further changes to the webserver configuration.
2: Redirect - Make all requests redirect to secure HTTPS access. Choose this for
new sites, or if youâre confident your site works on HTTPS. You can undo this
change by editing your web serverâs configuration.
Select the appropriate number [1-2] then [enter] (press âcâ to cancel): 1
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: //linuxpd2.my_dyanamic_dns_domain.org
and //officelinuxpd2.my_dyanamic_dns_domain.org
IMPORTANT NOTES:
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/fullchain.pem
Your key file has been saved at:
/etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/privkey.pem
Your cert will expire on 2020-05-0. To obtain a new or tweaked version of this certificate in the future, simply run certbot again with the âcertonlyâ option. To non-interactively renew all of
your certificates, run âcertbot renewâ - If you like Certbot, please consider supporting our work by:
Donating to ISRG / Letâs Encrypt:
Donating to EFF:
jason@linuxpd2:~$ sudo service apache2 restart
I am confused to as what is going on in the /etc/apache2/sites-enabled
or how i was suppossed to modify the virtual host.
I thought I had to create a new one that is why i made the officelinuxpd2.conf
but at this point I am lost. Below is a image of the folder and the content of each file:
<IfModule mod_ssl.c>
<VirtualHost *:443>
# The ServerName directive sets the request scheme, hostname and port that the server uses to identify itself. This is used when creating redirection URLs. In the context of virtual hosts, the ServerName specifies what hostname must appear in the request's Host: header to match this virtual host. For the default virtual host (this file) this value is not decisive as it is used as a last resort host regardless. However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
# -----------20170716 initial setup adders:
ServerName linuxpd2.my_dyanamic_dns_domain.org
Redirect permanent //linuxpd2.my_dyanamic_dns_domain.org/
# ---------- end initial setup adders -----------
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn, error, crit, alert, emerg. # It is also possible to configure the loglevel for particular modules, e.g.
#LogLevel info ssl:warn
# For most configuration files from conf-available/, which are enabled or disabled at a global level, it is possible to include a line for only one particular virtual host. For example the following line enables the CGI configuration for this host only after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
ServerAlias officelinuxpd2.my_dyanamic_dns_domain.org
SSLCertificateFile /etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/privkey.pem
</VirtualHost>
</IfModule>
000-default.conf
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that the server uses to identify itself. This is used when creating redirection URLs. In the context of virtual hosts, the ServerName specifies what hostname must appear in the request's Host: header to match this virtual host. For the default virtual host (this file) this value is not decisive as it is used as a last resort host regardless.However, you must set it for any further virtual host explicitly.
Redirect permanent / linuxpd2.my_dyanamic_dns_domain.org/
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn, error, crit, alert, emerg.It is also possible to configure the loglevel for particular modules, e.g.#LogLevel info ssl:warn
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
**default-ssl.conf**
<VirtualHost _default_:443>
# 20170716 initial installation of nextcloud updates are below
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
#----------- end updates---------------------
# error, crit, alert, emerg.
# modules, e.g.
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
# BrowserMatch "MSIE [2-6]" \
# nokeepalive ssl-unclean-shutdown \
# downgrade-1.0 force-response-1.0
SSLCertificateFile /etc/letsencrypt/live/linuxpd2.my_dyanamic_dns_domain.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/linuxpd2.my_dyanamic_dns_domain.org/privkey.pem
</VirtualHost>
</IfModule>
nextcloud.conf
Alias /nextcloud â/var/www/nextcloud/â
Options +FollowSymlinks
AllowOverride All
Satisfy Any
Dav off
officelinuxpd2.conf
VirtualHost *:443>
ServerName officelinuxpd2.my_dyanamic_dns_domain.org:443
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/cert.pem
SSLCertificateChainFile /etc/letsencrypt/live/officelinuxpd2.my_dyanamic_dns_domain.org/fullchain.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-G
SSLHonorCipherOrder >> the rest is the same as the collabora link
Any suggestions would be great
currently i am getting the error: The page isnât redirecting properly
thank you for your time
qu1nnThis text will be hidden
