I have different Synology servers (but all from ±series and with Intel Atom inside) and want to use Collabora. I follow your instructions was able to install the Docker image, which is running as well. But to configure Apache and all others, was not possible for me.
Because I´m no expert in this, could you support please?
Hi !
I’m trying to setting things up too
The standard instructions can’t help a lot : the Synology’s Docker package is very different from a standard Docker installation, and the reverse proxy settings have to be made in a specific settings panel (In Webstation, clled “Virtual Hosts”).
Here are some steps I followed hoping something will happen :
Creation of the subdomain office.domain.xx
Creation of the corresponding Lets Encrypt certificate in the Syno config panel
Create a reverse proxy (or Virtual Host in Syno) to office.domain.xx based on the port (HTTPS: 9980 / Document root: docker / Collabora (I created a collabora folder in the shared docker folder created automatically … Why, good question) / HSTS enabled / Apache 2.2 / PHP 5.6> The installation of Nextcloud does not work for Syngent with Nginx …)
There is also an “Environment” tab where I can enter execution commands …
For now, it does not work obviously. I do not understand how to configure the virtual host / reverse proxy, and I think the docker config deserves a little more settings …
Thanks for your advices
However, I have a field to enter execution commands in the docker no ?
I don’t even know how / if I can run my docker using the command line (In general, when you execute something by yourself on Synology, everything disappear at the next reboot…)
And could I consider the Virtual Host as the same thing than reverse proxy on Syno ?
Is anyone succeeded to make collabora work on docker with Synology ?
So far I have downloaded the image, setup the ports, make the reverse proxy in Application Portal and it fails/restart continuously… ( FATAL: Failed to fork child processes)
Message in a bottle for someone who maybe have made it
A lot of people also tried it in the german synology forum, but no one solved it ever.
Some people managed to start it with the orboan/collabora container, but they are only able to read and write in the files, but not save them.
