Hi all,
I decided to post about my situation after many days of troubleshooting. I recently installed NextCloud as snap on Ubuntu 18.04 and everything worked fine. I did the port forwarding and used Let’s Encrypt (from snap commands) to create the certificates for NC.
Then I decided to install Collabora server on the same machine to use the office functionality. I used the official Collaboration guides for installation mentioned here. However, in this guide, it is assumed that NC is installed manually (not snap). According to guides, I had to install Apache (or any other proxy/web server) to proxy the traffic to whether NC or Collabora.
I think there is a problem with my proxy configuration or something wrong with SSL certificates. When both Apache and snap are running, I can get to Apache page and Collabora should be running, but cannot get to NC page.
I can go to (port 443) link below and get to the page (meaning Collabora is responding?)
https://collabora.domain.com/loleaflet/dist/admin/admin.html
But when accessing the NC domain, the browser says “Did Not Connect: Potential Security Issue” and complain that the certificates are not for that NC domain I am trying to connect but the certificate is for Collabora domain. If I stop the Apache and let Snap running, I can access the NC domain with no issues (except I need to set the ports to 443 and 80 again! Is this problematic)
My Apache proxy config file (located under /etc/apache2/sites-available/) is as follows:
<VirtualHost *:444>
ServerName nextcloud.domain.com:444
ProxyPreserveHost On
ProxyPass / https://192.168.1.50/
ProxyPassReverse / https://192.168.1.50/
SSLProxyEngine on
SSLCertificateFile /etc/letsencrypt/live/nextcloud.domain.com/cert.pem
SSLCertificateChainFile /etc/letsencrypt/live/nextcloud.domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/nextcloud.domain.com/privkey.pem
</VirtualHost>
<VirtualHost *:443>
ServerName collabora.domain.com:443
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/collabora.domain.com/cert.pem
SSLCertificateChainFile /etc/letsencrypt/live/collabora.domain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/collabora.domain.com/privkey.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-$
SSLHonorCipherOrder on
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery$
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" wss://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
# Endpoint with information about availability of various features
ProxyPass /hosting/capabilities https://127.0.0.1:9980/hosting/capabilities retry=0
ProxyPassReverse /hosting/capabilities https://127.0.0.1:9980/hosting/capabilities
</VirtualHost>
To be honest, this is first time I am setting up proxy server that do not know how it works. Most of my config file is copied and think that is the issue If someone can have a look at it and guide me to the right direction, that would save me lots of headache and time.
