hello,
I installed collabora now several times, now I am in an restricted environment with very strict firewall rules (only some ports are allowed in and out), I have no access to.
I am using self signed certificates, and installed the CA to /resources/config/ca-bundle.crt as it told me.
I installed the ca-cert to my firefox browser too and that works fine.
But as I am opening a document it sticks at: connecting to cdnjs.cloudflare.com.
After that I blocked cloudflare in noscript (a javascript blocker) the document loads fine.
How can I disable connections to cloudflare on the server itself, so other users doesn’t need to install noscript?
the link is in the following files in the container
./usr/share/loolwsd/loleaflet/dist/admin/adminAnalytics.html:34:
./usr/share/loolwsd/loleaflet/dist/admin/admin.html:33
./usr/share/loolwsd/loleaflet/dist/admin/adminSettings.html:34
./usr/share/loolwsd/loleaflet/dist/loleaflet.html:27:
./usr/share/loolwsd/loleaflet/dist/loleaflet.html:35
./usr/share/loolwsd/loleaflet/dist/loleaflet.html:53
./usr/share/loolwsd/loleaflet/dist/.loleaflet.html.swp:5:
I made a workaround:
I downloaded several jquery files and stored them on my own space as did the following:
docker ps -a
to list the containers
docker exec -it /bin/bash
cd /usr/share/loolwsd/loleaflet/dist
grep -Hirn cloudflare * > ~/cloudflare.txt
to check where are the links in that and replaced withsed -i
the cloudflare links to my local device.
the same with:grep -Hirn googleapis * > ~/googleapis.txt
and replace with sed.
after that you can export your image with
docker export <container-id> | gzip -vc > filename.tar.gz
import for a restore:
cat collabora.tar.gz | docker import - collabora/import
The firewall seems to be fine with the googleapis yet, but I am thinking about to “localize” the 3 js files too.
Afternote:
take caution if you try that, at one machine it worked at another not (connection error and it blew up).
If you nuked your container then reinstall it with:
docker ps
docker stop <running-ID> (on the first collumn)
docker ps -a
docker rm <all ids with this collabora/code>
and restart as usual/before
