Hi all,
I moved my working NC instance behind an apache reverse proxy. Domain stayed the same. I put the overwritehost, overwriteprotocol and overwrite.cli.url in config.php. Everything works fine, including notify_push (that was another story :-))
However: Editing a document, Nextcloudoffice (with built-in CODE) starts to load but fails. In the browser console I can see that it tries to load scripts from the internal server name instead of the FQDN; ie from https://servername/⦠instead of https://mydomain.com/ā¦
My apache proxy config is:
<VirtualHost *:443>
ServerName mydomain.com
ServerAdmin admin@mydomain.com
Header always set Strict-Transport-Security "max-age=31536000; includeSubDomains"
SSLProtocol all -SSLv3 -TLSv1 -TLSv1.1
SSLProxyEngine on
SSLProxyVerify none
SSLProxyCheckPeerCN off
SSLProxyCheckPeerName off
SSLProxyCheckPeerExpire off
RewriteEngine On
RewriteRule ^/\.well-known/carddav https://%{SERVER_NAME}/nextcloud/remote.php/dav/ [R=301,L]
RewriteRule ^/\.well-known/caldav https://%{SERVER_NAME}/nextcloud/remote.php/dav/ [R=301,L]
RewriteRule ^/\.well-known/webfinger https://%{SERVER_NAME}/nextcloud/public.php?service=webfinger [QSA,L]
RewriteRule ^/\.well-known/nodeinfo https://%{SERVER_NAME}/nextcloud/index.php/.well-known/nodeinfo [R=301,L]
RewriteCond %{HTTP:Upgrade} websocket [NC]
RewriteCond %{HTTP:Connection} upgrade [NC]
ProxyPassMatch (.*)(\/websocket)$ "ws://servername/$1$2"
ProxyPreserveHost On
ProxyPass /push/ws ws://servername:7867/ws
ProxyPass /push/ https://servername:7867/
ProxyPass /.well-known !
ProxyPass / https://servername/
ProxyPassReverse /push/ https://servername:7867/
ProxyPassReverse / https://servername/
SSLCertificateFile /etc/letsencrypt/live/mydomain.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mydomain.com/privkey.pem
ProxyRequests Off
ProxyPreserveHost Off
</VirtualHost>
any hints & ideas what Iām missing?
Kind regards
el lobo
