- Not sure where to find this?
- Windows 11
- Apache/2.4.62
- Cloudflare Tunnel
- PHP version (e.g, 8.3):
replace me
- Yes
- When I am setting it up for the first time.
- AIO
- Yes, Cloudflare
I am installing Nextcloud AIO on windows 11 using docker. I am able to access it at 192.xxx.x.xx:8080 and I did the setup. When I go to cloudflare tunnel website it says the page can’t be displyed. I have it set to HTTPS with NO TLS 192.xxx.x.xx:11000.
I even tried localhost and HTTP etc but it still says the page can’t be displated.
Here is my docker compose -
services:
nextcloud:
image: ghcr.io/nextcloud-releases/all-in-one:latest
restart: always
init: true
volumes:
ports: # Apache (set in APACHE_PORT)
- 8080:8080 # AIO web interface
environment:
- APACHE_PORT=11000
- APACHE_IP_BINDING=0.0.0.0
- SKIP_DOMAIN_VALIDATION=true
volumes:
PASTE HERE
PASTE
PASTE HERE
Here is my logs from docker for nextcloud-aio-nextcloud
https://pastebin.com/TWLMqRKv
