CloudFlare cause issues?
My domain where NextCloud is running CloudFlare CDN does this interfere with sync etc?
I’m running server cron.
weird you want to use Cloudflare but it should run if you turn off all the optimizations.
CloudFlare is enabled on the domain space where nextcloud is situated, hence the query
It’ isn’t enabled for the sake of NextCloud.
