I have a Nextcloud server running inside Docker on one host IP:192.168.0.42. It is only using http. I have another host running an Nginx reverse proxy server utilizing a Lets encrypt SSL cert. To connect to Nextcloud via a browser, I use cloud.xxx.xxx (just an example). It works fine.
When I try to configure the windows client software. It asks for my server name. In the box, I put in cloud.xxx.xxx. My browser pops up for me to log in. The URL on the browser should be cloud.xxx.xxx, but instead it is 192.168.0.42.
I had this issue a couple of years ago before I was using Docker, but I cannot remember or find the fix. I believe it is a setting somewhere in a config file. Any help would be greatly appreciated.
I havenât heard about that setting, thank you. If I remember correctly the solution was to add the setting âNEXTCLOUD_TRUSTED_DOMAINS.â Iâll have a look at what you suggested.
