Nextcloud version (eg, 20.0.5): 24.0.4
Operating system and version (eg, Ubuntu 20.04): Arch
Apache or nginx version (eg, Apache 2.4.25): nginx …
PHP version (eg, 7.4):
External storage support 1.16.1
Backblaze B2 Bucket Settings:
Private: y
Default Encryption: y
External Storage Settings:
SSL: y
Encryption: y
Previews: y
Shares: y
Check for modifications: never
The client keeps reuploading files over and over again when the synced folder is backed by a S3 Bucket.
- Add S3 Bucket from Backblaze B2 as external storage
- add external storage from step 1 as sync folder in client
- copy files into folder and let client sync
- client keeps uploading files over and over again(also notice in Backblaze file browser how file version counts keep increasing)
Fehler PHP Error: Return type of Aws\Result::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#56
2022-10-16T21:04:25+0200
Fehler PHP Error: Return type of Aws\Result::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#13
Fehler PHP Error: Return type of Aws\Result::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#46
Fehler PHP Error: Return type of Aws\Result::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#36
Fehler PHP Error: Return type of & Aws\Result::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#26
Fehler PHP Error: Return type of Aws\Result::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#41
Fehler PHP Error: Aws\Credentials\Credentials implements the Serializable interface, which is deprecated. Implement __serialize() and __unserialize() instead (or in addition, if support for old PHP versions is necessary) at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Credentials/Credentials.php#8
Fehler PHP Error: Return type of Aws\Command::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#13
Fehler PHP Error: Return type of Aws\Command::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#56
Fehler PHP Error: Return type of Aws\Command::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#46
Fehler PHP Error: Return type of Aws\Command::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#36
Fehler PHP Error: Return type of & Aws\Command::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#26
Fehler PHP Error: Return type of Aws\Command::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#41
Fehler PHP Error: is_readable(): open_basedir restriction in effect. File(//.aws/config) is not within the allowed path(s): (/usr/share/webapps:/home/http/www/cloud.rfreyt.ag/data:/etc/webapps:/usr/lib/php:/var/lib/nextcloud:/var/log/nextcloud:/tmp) at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Retry/ConfigurationProvider.php#158
Fehler PHP Error: Return type of Aws\Endpoint\Partition::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#46
Fehler PHP Error: Return type of Aws\Endpoint\Partition::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#36
Fehler PHP Error: Return type of & Aws\Endpoint\Partition::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#26
Fehler PHP Error: Return type of Aws\Endpoint\Partition::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HasDataTrait.php#41
Fehler PHP Error: Return type of Aws\Api\AbstractModel::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Api/AbstractModel.php#46
Fehler PHP Error: Return type of Aws\Api\AbstractModel::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Api/AbstractModel.php#36
Fehler PHP Error: Return type of Aws\Api\AbstractModel::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Api/AbstractModel.php#30
Fehler PHP Error: Return type of Aws\Api\AbstractModel::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/Api/AbstractModel.php#41
Fehler PHP Error: Return type of Aws\HandlerList::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice at /usr/share/webapps/nextcloud/3rdparty/aws/aws-sdk-php/src/HandlerList.php#308
2022-10-16T21:04:18+0200
Warnung fulltextsearch Exception while cronIndex: OCA\FullTextSearch\Exceptions\PlatformNotSelectedException - Admin have not selected any IFullTextSearchPlatform
2022-10-16T20:55:02+0200
Warnung no app in context Sabre\DAV\Exception\NotFound: File with name /SofortUpload/1632060925024_39581928.mp4 could not be located
2022-10-16T20:52:48+0200
Fehler camerarawpreviews Exception: Unable to find preview data: /var/lib/nextcloud/apps/camerarawpreviews/vendor/exiftool/exiftool/exiftool.bin -json -preview:all -FileType '/tmp/oc_tmp_PqUJeJ' -> [{ "SourceFile": "/tmp/oc_tmp_PqUJeJ" }]
2022-10-16T20:45:39+0200
Fehler camerarawpreviews Exception: Unable to find preview data: /var/lib/nextcloud/apps/camerarawpreviews/vendor/exiftool/exiftool/exiftool.bin -json -preview:all -FileType '/tmp/oc_tmp_amtD5w' -> [{ "SourceFile": "/tmp/oc_tmp_amtD5w" }]
2022-10-16T20:45:38+0200
PASTE HERE
PASTE HERE
PASTE HERE
