I’ve been trying out the file access control feature and am having an odd issue with it…
I’m restricting access to files based on MIME type (JPG’s as a test) and although it does work (.jpg files are not downloaded by the client), it errors saying the file was deleted from the server and displays a red cross in the system tray.
Does anyone else have this same behavior? It doesn’t seem like a usable feature if you never get a “green tick” again… though I haven’t been able to find anyone else mentioning it, which makes me wonder if I’m doing something wrong.
I’ve tried version 13 and 14 of the server, the latest stable client, and one of the dailys (20181026), all show the same behavior. I’ve also tested on Windows and MacOS.
It may also be worth mentioning that the very first time the client syncs I do in fact get the green tick, but the next time it checks for changes it errors and I get the red cross again.
It may be I need to report it is a bug on github, but thought I’d check here first.
Thanks for any help!
