I click on my external storage device share. When I click on it, I am just taken to the All Files page on my instance. No errors or anything. Why is this happening?
Please use the support template… We can’t help you without.
Nextcloud version (eg, 20.0.5): 24.0.5
Operating system and version (eg, Ubuntu 20.04): Raspbian GNU/Linux 11 (bullseye)
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.54
PHP version (eg, 7.4): 8.0.1
Is this the first time you’ve seen this error? (Y/N): y
- add external sftp drive
- save/add
- connect to device in Files tab
UnexpectedValueException: no authentication parameters specified
Exception: Invalid webdav storage configuration
NOTE: These are old messages, and the most recent!
'instanceid' => 'a',
'passwordsalt' => 'a',
'secret' => 'a',
0 => '<ip>',
'version' => '24.0.5.1',
'overwrite.cli.url' => '<ip>/nextcloud',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => '<password>',
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'files_texteditor',
'updater.secret' => '<secret>',
error.log:
[Fri Sep 16 10:02:08.907489 2022] [mpm_prefork:notice] [pid 11969] AH00170: caught SIGWINCH, shutting down gracefully
[Fri Sep 16 10:02:09.388539 2022] [mpm_prefork:notice] [pid 12113] AH00163: Apache/2.4.54 (Raspbian) configured -- resuming normal operations
[Fri Sep 16 10:02:09.388747 2022] [core:notice] [pid 12113] AH00094: Command line: '/usr/sbin/apache2'
[Fri Sep 16 10:04:26.264115 2022] [access_compat:error] [pid 12117] [client <IP>:62305] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Fri Sep 16 11:37:02.358418 2022] [access_compat:error] [pid 12930] [client <IP>:49979] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Fri Sep 16 13:22:39.399440 2022] [access_compat:error] [pid 12863] [client <IP>:65265] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
cat: /sys/class/net/wlan0/speed: Invalid argument
cat: /sys/class/net/wlan0/duplex: Invalid argument
[Fri Sep 16 13:39:11.857073 2022] [access_compat:error] [pid 12933] [client <IP>:50639] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Fri Sep 16 13:39:55.712474 2022] [access_compat:error] [pid 12914] [client <IP>:50698] AH01797: client denied by server configuration: /var/www/nextcloud/data/.ocdata
