I’ve been trying to get Clean URL’s working, but nothing seems to change.
I have configured: ‘htaccess.RewriteBase’ => ‘/’,
I have mod_rewrite and mod_env enabled.
I ran sudo -u www-data php occ maintenance:update:htaccess
This updated my .htaccess file as follows, but it still nothing changed.
RewriteEngine on RewriteCond %{HTTPS} !=on RewriteRule .* https://%{SERVER_NAME}%{REQUEST_URI} [R,L] RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}] RewriteRule ^\.well-known/host-meta /public.php?service=host-meta [QSA,L] RewriteRule ^\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L] RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L] RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L] RewriteRule ^remote/(.*) remote.php [QSA,L] RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L] RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge/.* RewriteRule ^(?:\.|autotest|occ|issue|indie|db_|console).* - [R=404,L] AddType image/svg+xml svg svgz AddEncoding gzip svgz DirectoryIndex index.php index.html AddDefaultCharset utf-8 Options -Indexes ModPagespeed Off #### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####ErrorDocument 403 /core/templates/403.php
ErrorDocument 404 /core/templates/404.php
Options -MultiViews
RewriteRule ^core/js/oc.js$ index.php [PT,E=PATH_INFO:$1]
RewriteRule ^core/preview.png$ index.php [PT,E=PATH_INFO:$1]
RewriteCond %{REQUEST_FILENAME} !.(css|js|svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$
RewriteCond %{REQUEST_FILENAME} !core/img/favicon.ico$
RewriteCond %{REQUEST_FILENAME} !/remote.php
RewriteCond %{REQUEST_FILENAME} !/public.php
RewriteCond %{REQUEST_FILENAME} !/cron.php
RewriteCond %{REQUEST_FILENAME} !/core/ajax/update.php
RewriteCond %{REQUEST_FILENAME} !/status.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v1.php
RewriteCond %{REQUEST_FILENAME} !/ocs/v2.php
RewriteCond %{REQUEST_FILENAME} !/updater/
RewriteCond %{REQUEST_FILENAME} !/ocs-provider/
RewriteRule . index.php [PT,E=PATH_INFO:$1]
RewriteBase /
SetEnv front_controller_active true
DirectorySlash off
