Changing calendar order/default calendar
Hey, sorry if this has been addressed already, I searched but wasn’t able to find anything that helped.
I was wondering if the way to change the calendar order has been updated since this post:
or whether there’s any other ways to do so, as I’ve been unable to adjust the order. Clicking and dragging as suggested just results in the dragged calendar snapping back to where it was after I release, or sometimes in some other seemingly unrelated change of order amongst the other calendars.
Thanks in advance for any help!
Unfortunately you’ve ignored the support template and didn’t provide any information about your enviornment and the used software versions. I personally can tell you that it is working without any issues with Nextcloud 29.0.7 and Calendars app v4.7.16.
Sorry! The other post I saw asking about it didn’t seem to follow the template so I assumed it wasn’t always necessary, my mistake. I’m very new to all of this and there’s quite a few bits of the template I’m unsure of, but I’ve filled it out below as best I can. There are some logs I’m not able to access right now due to my location and extremely limited grasp of linux (currently away from the host system and unsure how to SSH in from here), but I’ve tried to answer everything I can and hopefully it’s still of some use, but if not I’ll follow up with the remaining logs as soon as I can get to them.
example
longer
example
here
Nextcloud version (eg, 29.0.5): Nextcloud Hub 9 30.0.0
Operating system and version (eg, Ubuntu 24.04): Pi OS Bookworm (Debian 12) / Linux 6.6.51+rpt-rpi-2712 aarch64
Apache or nginx version (eg, Apache 2.4.25): Unsure, but if it helps at all I’m running it through a Cloudflare tunnel
PHP version (eg, 8.3): 8.2.23
Calendar version: 5.0.0
  1. Make multiple calendars in Calendar app
  2. Try to rearrange them
Text was apparently too long for both this box and pastebin so I've uploaded a notepad file of it here:
https://mega.nz/file/HV5x0BKL#_eFmS-3bBKjiwB9TjB6NhxzGMsB6hO-xrI0oFsW2Tgs
PASTE HERE
PASTE HERE
PASTE HERE
Sorry again for my ignorance on this in general and the lack of some stuff requested, no worries if you can’t help from this limited info I appreciate there’s a lot missing.
I now have the same problem back again. Dragging and dropping (as suggested in the earlier ticket) no longer works.
Steps to reproduce:
  1. Have multiple calendars.
  2. In Calendar Settings, set the default calendar for incoming invitations to a calendar which is not the top one in the list of calendars.
  3. Manually create a new event. It will be assigned to the top calendar in the list of calendars.
Nextcloud 30.0.4, Calendar 6.1.1. apache2 2.4.62-1~deb12u2
charles@hawk:~$ php --version
PHP 8.2.26 (cli) (built: Nov 25 2024 17:21:51) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.26, Copyright (c) Zend Technologies
    with Zend OPcache v8.2.26, Copyright (c), by Zend Technologies
charles@hawk:~$
Browser is vivaldi-stable 7.0.3495.27-1 amd64. All of this on Debian 12.8
Log entry, possibly related as it occurred about the time I filed this reply:
[no app in context] Warning: Invalid defaultDaemonConfig data provided to provideInitialState by settings
	GET /index.php/settings/apps
	from 192.168.10.1 by charles at Dec 22, 2024, 3:10:27 PM
I have seen this elsewhere, however.
Unable to reorder agandas in calendar 5.0.8 / nexcloud 30.0.4 / PHP 8.2.20 / Apache …
Found some infos explaining the bug is not so solved :
