Change first ldap-configuration with CLI not possible
I have setup 2 ldap-configurations, I see both with:
sudo -u www-data php occ ldap:show-config
I can enable/disable the second configuration, but not the first, because there is no name. The second have a name:
Configuration | s01
I have try s00 and without name but it does not work.
Any ideas?
Unfortunately, I have just locked myself out.
Link from help: Using the occ command — Nextcloud latest Administration Manual latest documentation
What do you mean by it has no name?
s01 is the first one. Typically s02 would be the second one.
You may be able to login by appending ?direct=1 to your Nextcloud URL.
OK, here I have save the (anonymized) output from “sudo -u www-data php occ ldap:show-config”:
| Configuration                 |        |
| hasMemberOfFilterSupport      | 1        |
| homeFolderNamingRule          | attr:uid        |
| lastJpegPhotoLookup           | 0        |
| ldapAdminGroup                |        |
| ldapAgentName                 |        |
| ldapAgentPassword             | ***        |
| ldapAttributeAddress          |        |
| ldapAttributeBiography        |        |
| ldapAttributeFediverse        |        |
| ldapAttributeHeadline         |        |
| ldapAttributeOrganisation     |        |
| ldapAttributePhone            |        |
| ldapAttributeRole             |        |
| ldapAttributeTwitter          |        |
| ldapAttributeWebsite          |        |
| ldapAttributesForGroupSearch  |        |
| ldapAttributesForUserSearch   |        |
| ldapBackgroundHost            |        |
| ldapBackgroundPort            |        |
| ldapBackupHost                |        |
| ldapBackupPort                |        |
| ldapBase                      | dc=example,dc=de        |
| ldapBaseGroups                | dc=example,dc=de        |
| ldapBaseUsers                 | dc=example,dc=de        |
| ldapCacheTTL                  | 600        |
| ldapConfigurationActive       | 1        |
| ldapConnectionTimeout         | 15        |
| ldapDefaultPPolicyDN          |        |
| ldapDynamicGroupMemberURL     |        |
| ldapEmailAttribute            | mail        |
| ldapExperiencedAdmin          | 0        |
| ldapExpertUUIDGroupAttr       |        |
| ldapExpertUUIDUserAttr        | employeeNumber        |
| ldapExpertUsernameAttr        |        |
| ldapExtStorageHomeAttribute   |        |
| ldapGidNumber                 | gidNumber        |
| ldapGroupDisplayName          | cn        |
| ldapGroupFilter               | (&(|(objectclass=groupOfNames)))        |
| ldapGroupFilterGroups         |        |
| ldapGroupFilterMode           | 0        |
| ldapGroupFilterObjectclass    | groupOfNames        |
| ldapGroupMemberAssocAttr      | uniqueMember        |
| ldapHost                      | localhost        |
| ldapIgnoreNamingRules         |        |
| ldapLoginFilter               | (&(&(|(objectclass=person))(|(memberof=cn=owncloud,ou=programme,ou=groups,dc=example,dc=de)))(|(employeeNumber=%uid))) |
| ldapLoginFilterAttributes     | employeeNumber        |
| ldapLoginFilterEmail          | 0        |
| ldapLoginFilterMode           | 1        |
| ldapLoginFilterUsername       | 0        |
| ldapMatchingRuleInChainState  | unknown        |
| ldapNestedGroups              | 0        |
| ldapOverrideMainServer        |        |
| ldapPagingSize                | 500        |
| ldapPort                      | 389        |
| ldapQuotaAttribute            |        |
| ldapQuotaDefault              |        |
| ldapTLS                       | 0        |
| ldapUserAvatarRule            | default        |
| ldapUserDisplayName           | cn        |
| ldapUserDisplayName2          |        |
| ldapUserFilter                | (&(|(objectclass=inetOrgPerson)(objectclass=person))(|(memberof=cn=owncloud,ou=Programme,ou=groups,dc=example,dc=de))) |
| ldapUserFilterGroups          | owncloud        |
| ldapUserFilterMode            | 1        |
| ldapUserFilterObjectclass     | inetOrgPerson;person        |
| ldapUuidGroupAttribute        | auto        |
| ldapUuidUserAttribute         | auto        |
| markRemnantsAsDisabled        | 0        |
| turnOffCertCheck              | 0        |
| turnOnPasswordChange          | 0        |
| useMemberOfToDetectMembership | 1        |
| Configuration                 | s01        |
| hasMemberOfFilterSupport      | 0        |
| homeFolderNamingRule          |        |
| ldapAdminGroup                |        |
| ldapAgentName                 |        |
| ldapBackupHost                |        |
| ldapBackupPort                | 636        |
| ldapConfigurationActive       | 0        |
| ldapExpertUUIDUserAttr        |        |
| ldapGroupMemberAssocAttr      |        |
| ldapHost                      | ldaps://auth-server.example.de        |
| ldapLoginFilterAttributes     |        |
| ldapLoginFilterMode           | 0        |
| ldapLoginFilterUsername       | 1        |
| ldapPort                      | 636        |
| ldapTLS                       | 0        |
| ldapUserDisplayName           | displayName        |
| ldapUserFilterGroups          |        |
| ldapUserFilterObjectclass     |        |
| turnOffCertCheck              | 1        |
the first config have no name, so I can not change the config over CLI.
Found the solution here: Weird ldap configID required for the ldap:test-config occ command (OC 7.0.5) · Issue #13981 · owncloud/core · GitHub
If you need to set any configuration value, you can do ./occ ldap:set-config '' key value
