Is it possible to change the default write permissions to external storage? Need files to be written with group write permissions. I’m using snappy Ubuntu 16.04.2 LTS on a NextCloud Box.
Details:
- FreeNas sharing to NextCloud via WebDav. FreeNas only allows you to share WebDav using the webdav user.
- On FreeNas, each dataset has permissions set as root owner and the dataset name as the group. e.g.: Owner: root. Group: projects.
- Each user on the network has their own primary group (e.g. user: stephen. primary group: stephen).
- Each user has an auxiliary group for each dataset (e.g. user: stephen. auxiliary groups: projects, assets…).
This allows us to restrict shares to certain users (e.g. if we have a freelancer in the office, they can’t access the finance dataset).
Unfortunately, when data is synced back to FreeNas through NextCloud via a client app, the files are written as read-only for the group.
