after upgrade from 13.0.1 to 13.0.5 I get following message:
Some files did not pass the integritytests.
After clicking on the list-of-failed-files I get following Page:
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- contacts_old
- EXCEPTION
- OC\IntegrityCheck\Exceptions\InvalidSignatureException
- Certificate is not valid for required scope. (Requested: contacts_old, current: CN=contacts)
Raw output
Array
[contacts_old] => Array
[EXCEPTION] => Array
[class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException
[message] => Certificate is not valid for required scope. (Requested: contacts_old, current: CN=contacts)
I don’t know where to search for this problem.
I’ve found on the server filesystem following directorys:
nextcloud/data/updater-octwfmkva7ix/backups/nextcloud-13.0.1.1/apps/contacts
nextcloud/data/updater-octwfmkva7ix/backups/nextcloud-13.0.1.1/apps/contacts_old
That’s all I can find on the server. Can someone give me a hint what to do?
Actually it seems that the NC-Installation works correctly
Thanks in advance
glini
P.S. I found out that these directorys exist also in the normal apps directory. I tried to remove the contacts_old directory, but no change
