Nextcloud version (eg, 20.0.5): 22.2.3
Operating system and version (eg, Ubuntu 20.04): Debian GNU/Linux 11 (bullseye) on Raspberry Pi 4
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.51
PHP version (eg, 7.4): 7.4.27
The issue you are facing: I can’t upload files over 10 mb and also can’t create any folders. WebUI and Desktop Client (Windows/macOS) show the same problems.
I’ve also checked the forum and google for countless hours, trying every possible solution and nothing helped yet.
Is this the first time you’ve seen this error? (Y/N): Yes
Steps to replicate it (folder):
- Try to create a folder
- Get hit with “Der Ordner konnte nicht erstellt werden “test””
Steps to replicate it (file with client):
- Put something in the nextcloud folder
- See "Server replied “403 FORBIDDEN” to “MKCOL https://…” in the event log
Steps to replicate it (file with webUI)
- Try to upload something
- Get hit with “Upload cancelled”
https://pastebin.com/HrZxycyn
'instanceid' => 'rm',
'passwordsalt' => 'rm',
'secret' => 'rm',
0 => 'server',
1 => 'tnm.mine.nu',
2 => '192.168.178.4',
3 => 'server.wildfall.net',
'datadirectory' => '/var/www/html/nextcloud/data',
'version' => '22.2.3.0',
'overwrite.cli.url' => 'http://server/nextcloud',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost',
'dbuser' => 'rm',
'dbpassword' => 'rm',
'theme' => '',
'loglevel' => 2,
'updater.secret' => 'rm',
https://pastebin.com/1adfCWGn
