Can't Run Background Jobs with System Cron
Nextcloud version: 21.0.2
Operating system and version: Ubuntu 20.04
Apache or nginx version: Apache/2.4.41
PHP version: 7.4
When I set background jobs to cron under basic settings and add the line
*/5 * * * * php -f /var/www/nextcloud/cron.php
to crontab using sudo -u www-data crontab -e it does not update the “Last job ran…” notification on the settings menu. When I run cron.php from the cli it runs just fine (I had to set the log_level to 1 to get this to run otherwise it would just hang indefinitely) and it updates the “Last job ran…” notification. If I check journalctl | grep CRON I can see that the cron job is run every 5 minutes as expected, but the notification does not update. After looking through the forums I tried updating the memory_limit under /etc/php/7.4/cli/php.ini as I only had it set in …/apache2/php.ini, but this did not work. This problem has only become apparent after updating to NC 21.0.2 from NC 20.0.8 however I cannot verify whether it was working before the update as I was just using AJAX then. Also, it may be of note that I had to add apc.enable_cli=1 to /etc/php/7.4/mods-available/apcu.ini as well as have ‘memcache.local’ => ‘\OC\Memcache\APCu’, in $NEXTCLOUD/config/config.php in order to get things like occ to run after updating.
Yes
  1. Change to system cron
  2. Add relevant cronjob to crontab
  3. Notice that last background job notification does not update
I will provide any relevant logs if necessary, but the only relevant thing the logs appear to show is occasionally some logging from cron.php if I run on cli.
Same here. I tried to switch to webcron and AJAX, but it also doesn’t run tasks. Logs don’t contain anything related to cron jobs.
+1
https://help.nextcloud.com/t/backgroud-jobs-with-cron/120195
I probably have a solution.
When i tried to run the occ command for some reason, i got an error message about \OC\Memcache\APCu, and some dependencies not being installed. It turned out that i had to enable APC in the CLI, by setting apc.enable_cli=1 in my PHP configuration.
After that, both cron jobs and OCC work just fine.
Hope that helps!
I already have APC set and it doesn’t work, but thanks anyways.
That’s what i thought, too, as the NC web worked just fine. What i had to enable is the CLI support of APC. Sorry if that was clear already.
