Hey,
I can’t login via the web interface. The login via apps/webdav (Android, Linux client) still works.
My server stopped yesterday suddenly and I had to restart it manually after systemd failed to reboot:
auth.log
Jun 12 02:25:00 XXX systemd-logind[1150]: Creating /run/nologin, blocking further logins...
Jun 12 02:30:00 XXX systemd-logind[1150]: System is rebooting.
My nextcloud is running as a nextcloud:fpm
docker instance with nginx as reverse proxy (and an slighty adapted config). I am yet on Nextcloud 19.0.0.12 due to the auto update some days ago. I tried a repair attempt, but the nextcloud is not complaining about anything (apart from 2 birthday calendars
. I don’t know if the login problem existed yet before the update.
What can I do next, what should I check?
Cheers
2020-06-14 - update 1 - with config.php
> 'loglevel' => 0
- I get a NotLoggedInException exception, but nothing more:
{"reqId":"7N5iBuZ8bdu7vsxyQyAP","level":0,"time":"2020-06-14T18:51:50+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"cron","method":"GET","url":"/cron.php","message":"Finished OC\\Command\\CommandJob job with ID 508 in 1 seconds","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:77.0) Gecko/20100101 Firefox/77.0","version":"19.0.0.12"}
{"reqId":"JLTJ3QEhBAy98FGZR34G","level":0,"time":"2020-06-14T18:52:02+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"core","method":"GET","url":"/apps/files/","message":{"Exception":"OC\\AppFramework\\Middleware\\Security\\Exceptions\\NotLoggedInException","Message":"Current user is not logged in","Code":401,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/Middleware/MiddlewareDispatcher.php","line":98,"function":"beforeController","class":"OC\\AppFramework\\Middleware\\Security\\SecurityMiddleware","type":"->","args":[{"__class__":"OCA\\Files\\Controller\\ViewController"},"index"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":98,"function":"beforeController","class":"OC\\AppFramework\\Middleware\\MiddlewareDispatcher","type":"->","args":[{"__class__":"OCA\\Files\\Controller\\ViewController"},"index"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":137,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Files\\Controller\\ViewController"},"index"]},{"file":"/var/www/html/lib/private/AppFramework/Routing/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Files\\Controller\\ViewController","index",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"files.view.index"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"_route":"files.view.index"}]},{"file":"/var/www/html/lib/private/Route/Router.php","line":297,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"_route":"files.view.index"}]},{"file":"/var/www/html/lib/base.php","line":1007,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/files/"]},{"file":"/var/www/html/index.php","line":37,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/AppFramework/Middleware/Security/SecurityMiddleware.php","Line":142,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:77.0) Gecko/20100101 Firefox/77.0","version":"19.0.0.12"}
- when trying to reset the user password per mail I get a CSRF exception and the web interface tells me: Couldn’t send reset email. Please contact your administrator.
{"reqId":"kP3RLAn4i2M1uSNKs8At","level":0,"time":"2020-06-14T19:07:56+00:00","remoteAddr":"XXXX.XXX.XXX.XXX","user":"--","app":"cron","method":"GET","url":"/cron.php","message":"Finished OC\\Command\\CommandJob job with ID 513 in 1 seconds","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:77.0) Gecko/20100101 Firefox/77.0","version":"19.0.0.12"}
{"reqId":"Cx9Y4OWGGW5OR8MUa8cw","level":0,"time":"2020-06-14T19:08:00+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"core","method":"POST","url":"/lostpassword/email","message":{"Exception":"OC\\AppFramework\\Middleware\\Security\\Exceptions\\CrossSiteRequestForgeryException","Message":"CSRF check failed","Code":412,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/Middleware/MiddlewareDispatcher.php","line":98,"function":"beforeController","class":"OC\\AppFramework\\Middleware\\Security\\SecurityMiddleware","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LostController"},"email"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":98,"function":"beforeController","class":"OC\\AppFramework\\Middleware\\MiddlewareDispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LostController"},"email"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":137,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OC\\Core\\Controller\\LostController"},"email"]},{"file":"/var/www/html/lib/private/AppFramework/Routing/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OC\\Core\\Controller\\LostController","email",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"core.lost.email"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteActionHandler","type":"->","args":[{"_route":"core.lost.email"}]},{"file":"/var/www/html/lib/private/Route/Router.php","line":297,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"_route":"core.lost.email"}]},{"file":"/var/www/html/lib/base.php","line":1007,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/lostpassword/email"]},{"file":"/var/www/html/index.php","line":37,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/AppFramework/Middleware/Security/SecurityMiddleware.php","Line":180,"CustomMessage":"--"},"userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:77.0) Gecko/20100101 Firefox/77.0","version":"19.0.0.12"}
- The login-loop section in the documentation does not help much, as those directories do not exists anywhere (neither in the nc
app
,db
,redis
nor in myproxy
container)
chown nginx:nginx /var/lib/php/session/
chown root:nginx /var/lib/php/wsdlcache/
chown root:nginx /var/lib/php/opcache/
2020-06-12
nextcloud.log:
{"reqId":"CMjZu2rS45nmnMw9tbjC","level":0,"time":"2020-06-05T04:27:19+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"starting upgrade from 18.0.4.2 to 19.0.0.12","userAgent":"--","version":"18.0.4.2"}
the last log message is from "2020-06-07T16:41:25+00:00"
{"reqId":"CMjZu2rS45nmnMw9tbjC","level":1,"time":"2020-06-05T04:27:39+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::maintenanceDisabled: Turned off maintenance mode","userAgent":"--","version":"19.0.0.12"}
{"reqId":"CMjZu2rS45nmnMw9tbjC","level":1,"time":"2020-06-05T04:27:39+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::resetLogLevel: Reset log level to Warning(2)","userAgent":"--","version":"19.0.0.12"}
{"reqId":"Kuyw6Hu3ys27V8dUWG2u","level":3,"time":"2020-06-05T20:16:53+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["calendar.view.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["calendar.view.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["calendar.view.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["calendar.view.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
{"reqId":"Kuyw6Hu3ys27V8dUWG2u","level":3,"time":"2020-06-05T20:16:53+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["photos.page.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["photos.page.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["photos.page.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["photos.page.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
{"reqId":"Kuyw6Hu3ys27V8dUWG2u","level":3,"time":"2020-06-05T20:16:53+00:00","remoteAddr":"XXX.XXX.XXX.XXX","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"tasks.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["tasks.page.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["tasks.page.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["tasks.page.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["tasks.page.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
{"reqId":"dqMxYegnLkwRn8WydhAj","level":3,"time":"2020-06-07T16:41:25+00:00","remoteAddr":"YYYY.YYY.YYY.YYY","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"calendar.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["calendar.view.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["calendar.view.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["calendar.view.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["calendar.view.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
{"reqId":"dqMxYegnLkwRn8WydhAj","level":3,"time":"2020-06-07T16:41:25+00:00","remoteAddr":"YYYY.YYY.YYY.YYY","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["photos.page.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["photos.page.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["photos.page.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["photos.page.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
{"reqId":"dqMxYegnLkwRn8WydhAj","level":3,"time":"2020-06-07T16:41:25+00:00","remoteAddr":"YYYY.YYY.YYY.YYY","user":"--","app":"no app in context","method":"OPTIONS","url":"/remote.php/","message":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"tasks.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->","args":["tasks.page.index",[],1]},{"file":"/var/www/html/lib/private/Route/CachingRouter.php","line":60,"function":"generate","class":"OC\\Route\\Router","type":"->","args":["tasks.page.index",[],false]},{"file":"/var/www/html/lib/private/URLGenerator.php","line":83,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->","args":["tasks.page.index",[]]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":294,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->","args":["tasks.page.index"]},{"file":"/var/www/html/lib/private/NavigationManager.php","line":115,"function":"init","class":"OC\\NavigationManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ThemingDefaults.php","line":183,"function":"getAll","class":"OC\\NavigationManager","type":"->","args":["guest"]},{"file":"/var/www/html/lib/private/legacy/OC_Defaults.php","line":263,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->","args":[]},{"file":"/var/www/html/lib/public/Defaults.php","line":169,"function":"getLongFooter","class":"OC_Defaults","type":"->","args":[]},{"file":"/var/www/html/core/templates/layout.guest.php","line":55,"function":"getLongFooter","class":"OCP\\Defaults","type":"->","args":[]},{"file":"/var/www/html/lib/private/Template/Base.php","line":178,"args":["/var/www/html/core/templates/layout.guest.php"],"function":"include"},{"file":"/var/www/html/lib/private/Template/Base.php","line":150,"function":"load","class":"OC\\Template\\Base","type":"->","args":["/var/www/html/core/templates/layout.guest.php",null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"fetchPage","class":"OC\\Template\\Base","type":"->","args":[null]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":213,"function":"fetchPage","class":"OC_Template","type":"->","args":[null]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":301,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":84,"function":"printErrorPage","class":"OC_Template","type":"::","args":["Path not found","",404]},{"file":"/var/www/html/remote.php","line":169,"function":"handleException","args":[{"__class__":"RemoteException"}]}],"File":"/var/www/html/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":143,"CustomMessage":"--"},"userAgent":"gvfs/1.36.1","version":"19.0.0.12"}
Repair attempt:
$ php occ maintenance:repair
- Repair MySQL collation
- All tables already have the correct collation -> nothing to do
- Repair mime types
- Clean tags and favorites
- 0 tags of deleted users have been removed.
- 0 tags for delete files have been removed.
- 0 tag entries for deleted tags have been removed.
- 0 tags with no entries have been removed.
- Repair invalid shares
- Move .step file of updater to backup location
- Fix potential broken mount points
- No mounts updated
- Add log rotate job
- Clear frontend caches
- Image cache cleared
- SCSS cache cleared
- JS cache cleared
- Clear every generated avatar on major updates
- Add preview background cleanup job
- Queue a one-time job to cleanup old backups of the updater
- Cleanup invalid photocache files for carddav
- Add background job to cleanup login flow v2 tokens
- Remove potentially over exposing share links
- No need to remove link shares.
- Clear access cache of projects
- Reset generated avatar flag
- Update name of the stored view
- Fix component of birthday calendars
- 2 birthday calendars updated.
- Regenerating birthday calendars to use new icons and fix old birthday events without year
- Repair step already executed
- Fix broken values of calendar objects
0 [->--------------------------]
- Registering building of calendar search index as background job
- Registering background jobs to update cache for webcal calendars
- Added 0 background jobs to update webcal calendars
- Registering building of calendar reminder index as background job
- Clean up orphan event and contact data
- 0 events without a calendar have been cleaned up
- 0 properties without an events have been cleaned up
- 0 changes without a calendar have been cleaned up
- 0 cached events without a calendar subscription have been cleaned up
- 0 changes without a calendar subscription have been cleaned up
- 0 contacts without an addressbook have been cleaned up
- 0 properties without a contact have been cleaned up
- 0 changes without an addressbook have been cleaned up
- Remove activity entries of private events
- Removed 0 activity entries
- Delete orphaned ACL rules
- Fix the share type of guest shares when migrating from ownCloud
- Copy the share password into the dedicated column
- Set existing shares as accepted
- Update OAuth token expiration times
- Switches from default updater server to the customer one if a valid subscription is available
- Add background job to check for backup codes
- Populating added database structures for workflows
