example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.4
Operating system and version (eg, Ubuntu 17.04): Ubuntu Server 18.04 LTS
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.14.0
PHP version (eg, 7.1): 7.2
I can only sync my calendar from Nextcloud to my phone. For unknown reasons, events entered on the Android don’t show up in Nextcloud.
- On the Android, create an event in Calendar
- Click sync
- Check Nextcloud
PASTE HERE
PASTE HERE
2019/09/29 17:03:19 [error] 11963#11963: *10825 access forbidden by rule, client: 192.168.44.1, server: koalatyworks.com, request: "GET /.well-known/autoconfig/mail/config-v1.1.xml?emailaddress=wizard%40koalatyworks.com HTTP/2.0", host: "koalatyworks.com"
Any help/insights welcome!
