example
longer
example
here
Hello, I’m a newbie…
Nextcloud version (eg, 18.0.2): 20.0.1
Cloudamo Hosting
With the same account, same NextCloud instance :
- From an Enterprise PC with Edge Chromium : I can upload a file but i can’t create a folder (error message : can’t create folder xxx")
- From my Home PC with Edge Chromium : I can create a folder
So it’s not linked to my rights
So linked to my office environment => web browser settings or Proxy or…
Any advice ?
