Can't connect with nextcloud remotely on my subdomain
edit - not sure how but the response i made before it worked appeared after the solved part…
i think all i need to sort out now is the dynamic IP issue …
thanks all
ye let us know how that works out for you. it is the only ongoing issue I have.
it still seems to be working despite 3 x public ip address changes in the past 24 hours
i thought i would have to add some kind of CNAME entry in my web hosts DNS settings - i expect it will go toots up at some point…
i do have another question regarding cron jobs - if i can’t get that to work, i shall start another topic
