Can't connect to Nextcloud AIO Interface - Not a fresh install
example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud AIO v6.3.0
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04.2 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache , not find
PHP version (eg, 7.4): 8.1.21
I cannot connect to my AIO interface. No changes have been made in the instance config. I could still connect to it less than a week ago I would say.
The instance works well all like the applications but it remains problematic because I no longer have backups and updates via the stable channel.
The certificate is renewed well without problem, I have been using the reverse proxy nginx proxy manager since the installation of my nextcloud instance without any worries and having perfectly followed the installation doc.
  1. connect to your nextcloud instance
  2. try to connect to the AIO interface from the administration settings
  3. cannot because the browser indicates a certificate error (url: https://mydomain:8080/api/auth)
 2023-08-10 06:02:16.052506+02
(1 row)
+ '[' -n '' ']'
+ set +x
Installing imagemagick via apk...
Enabling Imagick...
Configuring Redis as session handler...
Setting php max children...
Applying one-click-instance settings...
System config value one-click-instance set to boolean true
System config value one-click-instance.user-limit set to integer 100
System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
support already enabled
Adjusting log files...
System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
System config value logfile set to string /var/www/html/data/nextcloud.log
Config value logfile for app admin_audit set to /var/www/html/data/audit.log
System config value updatedirectory set to string /nc-updater
Applying network settings...
System config value trusted_domains => 1 set to string extranet.chateaudesroure.fr
System config value overwrite.cli.url set to string https://extranet.chateaudesroure.fr/
System config value htaccess.RewriteBase set to string /
.htaccess has been updated
System config value files_external_allow_create_new_local set to boolean false
System config value trusted_proxies => 0 set to string 127.0.0.1
System config value trusted_proxies => 1 set to string ::1
Config value base_endpoint for app notify_push set to https://extranet.chateaudesroure.fr/push
Config value wopi_url for app richdocuments set to https://extranet.chateaudesroure.fr/
System config value allow_local_remote_servers set to boolean true
No ipv6-address found for extranet.chateaudesroure.fr.
Config value wopi_allowlist for app richdocuments set to 162.19.74.125,127.0.0.1/8,192.168.0.0/16,172.16.0.0/12,10.0.0.0/8,fd00::/8,::1,127.0.1.1,0.0.0.0/0
Config value recording_servers of app spreed deleted
[10-Aug-2023 06:04:21] NOTICE: fpm is running, pid 382
[10-Aug-2023 06:04:21] NOTICE: ready to handle connections
Activating collabora config...
Activated any config changes
[10-Aug-2023 12:45:24] WARNING: [pool www] child 7798 exited on signal 9 (SIGKILL) after 1348.439296 seconds from start
[10-Aug-2023 12:45:25] NOTICE: [pool www] child 8263 started
[10-Aug-2023 18:53:26] NOTICE: Terminating ...
[10-Aug-2023 18:53:26] NOTICE: exiting, bye-bye!
Waiting for database to start...
              now
 2023-08-10 18:53:46.103105+02
(1 row)
+ '[' -n '' ']'
+ set +x
              now
 2023-08-10 18:54:40.419903+02
(1 row)
+ '[' -n '' ']'
+ set +x
[10-Aug-2023 18:56:48] NOTICE: fpm is running, pid 359
[10-Aug-2023 18:56:48] NOTICE: ready to handle connections
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'toto',
    'port' => 6379,
  'overwritehost' => 'extranet.chateaudesroure.fr',
    0 => 'localhost',
    1 => 'extranet.chateaudesroure.fr',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '26.0.4.2',
  'overwrite.cli.url' => 'https://extranet.chateaudesroure.fr/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database',
  'instanceid' => 'oc0h8io4hmst',
  'loglevel' => '2',
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => '10485760',
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => '2048',
  'preview_max_y' => '2048',
  'jpeg_quality' => '60',
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => '30',
  'share_folder' => '/Shared',
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
  'default_language' => 'fr',
  'default_locale' => 'fr_FR',
  'default_phone_region' => 'FR',
  'allow_user_to_change_display_name' => false,
  'auto_logout' => true,
  'force_locale' => 'fr_FR',
  'skeletondirectory' => '',
  'allow_local_remote_servers' => true,
  'mail_smtpauth' => 1,
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'data-fingerprint' => 'c1dfd2d46e058358729357f004e3eaa8',
  'updatedirectory' => '/nc-updater',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
Waiting for Nextcloud to start...
[Thu Aug 10 06:04:23.438259 2023] [mpm_event:notice] [pid 99:tid 139733688884040] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Thu Aug 10 06:04:23.439177 2023] [core:notice] [pid 99:tid 139733688884040] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1691640263.458554,"msg":"using provided configuration","config_file":"/tmp/Caddyfile","config_adapter":""}
[Thu Aug 10 12:45:24 2023] [error] [client: 90.5.219.203, 172.22.0.1] [AH01067: Failed to read FastCGI header] [Mozilla/5.0 (Android) Nextcloud-Talk v17.0.2]
[Thu Aug 10 12:45:24 2023] [error] [(104)Connection reset by peer] [client: 90.5.219.203, 172.22.0.1] [AH01075: Error dispatching request to : ] [Mozilla/5.0 (Android) Nextcloud-Talk v17.0.2]
{"level":"error","ts":1691685124.6072571,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
[Thu Aug 10 18:53:26 2023] [error] [client: 90.5.219.203, 172.22.0.1] [AH01067: Failed to read FastCGI header] [Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/116.0]
[Thu Aug 10 18:53:26 2023] [error] [(104)Connection reset by peer] [client: 90.5.219.203, 172.22.0.1] [AH01075: Error dispatching request to : ] [Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/116.0]
{"level":"info","ts":1691686610.8340054,"msg":"using provided configuration","config_file":"/tmp/Caddyfile","config_adapter":""}
[Thu Aug 10 18:56:50.847580 2023] [mpm_event:notice] [pid 101:tid 140255200721736] AH00489: Apache/2.4.57 (Unix) configured -- resuming normal operations
[Thu Aug 10 18:56:50.847644 2023] [core:notice] [pid 101:tid 140255200721736] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"error","ts":1691686936.1193702,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"context canceled"}
Here, I think I have given the elements that I could. All help is welcome. I’m quite anxious to do some deep testing on my own because the instance is running fine in the foreground, so I wouldn’t want to crash it completely.
Regards,
Hi, can you post the mastercontainer logs here?
Hello and thank you for your input.
Here are the mastercontainer logs obtained via the command: docker logs nextcloud-aio-mastercontainer.
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
++ head -1 /mnt/docker-aio-config/data/daily_backup_time
+ BACKUP_TIME=04:00
+ export BACKUP_TIME
+ export DAILY_BACKUP=1
+ DAILY_BACKUP=1
++ sed -n 2p /mnt/docker-aio-config/data/daily_backup_time
+ '[' '' '!=' automaticUpdatesAreNotEnabled ']'
+ export AUTOMATIC_UPDATES=1
+ AUTOMATIC_UPDATES=1
+ set +x
Daily backup script has started
[29-Jul-2023 04:00:56] NOTICE: fpm is running, pid 110
[29-Jul-2023 04:00:56] NOTICE: ready to handle connections
grep: write error: Broken pipe
[Sat Jul 29 04:00:56.570475 2023] [mpm_event:notice] [pid 106:tid 139747837066056] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.1 configured -- resuming normal operations
[Sat Jul 29 04:00:56.570705 2023] [core:notice] [pid 106:tid 139747837066056] AH00094: Command line: 'httpd -D FOREGROUND'
{"level":"info","ts":1690603256.582729,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
Starting mastercontainer update...
(The script might get exited due to that. In order to update all the other containers correctly, you need to run this script with the same settings a second time.)
Waiting for watchtower to stop
Creating daily backup...
Waiting for backup container to stop
Starting and updating containers...
Waiting for the Nextcloud container to start
Sending backup notification...
Daily backup script has finished
Deleted Images:
untagged: nextcloud/aio-watchtower@sha256:035e24cfd7df048e59f51c0015ae7f7e5c1016ac13fd3470543ac905f7f1cb16
deleted: sha256:e7ed8be21397ab4b7cdc99a7f2b661d0a7b5fb5118bf743b14ca2824c6a11f7b
deleted: sha256:3805a63f0fdc7026ca531908093a14a1efb39a180f57b52b15990f6df2133533
deleted: sha256:cabb7281d6eae0063a7717f471aeb8cfc8476b4a1208e9fb6c4a9a7cfb8159c9
deleted: sha256:847b9b8dffc9f012d688f47cc5a72598d94ecc0a41a8a07a421d801e75f049f7
untagged: nextcloud/aio-postgresql@sha256:85785e7738515b07551b2ea27f2a43ad557eb98c97cdad28562e5644b9ab0b3f
deleted: sha256:13382909fa48c1111622056979aa5a65c7cb48bcf43fcf159cfe5497e7d325e4
deleted: sha256:f370633e5512ed6457d1d54aa536a3871aa3143661e8281d76d0975e2963e2e6
deleted: sha256:ccd3b32cb80147385827a56335a34e070e122fac1eaee7a951eadd398c548754
deleted: sha256:50b586f15d0b78ace26d0a349a760dd82c497ae047553a28c72bdd4e87d05e07
deleted: sha256:10d9935a9c774006e70f470f2f8718d631d521c0ae7bcf261b9e625cafcc6be6
untagged: nextcloud/aio-apache@sha256:5ef1a9b953b03f44437326dd9578134c4bcfb18c6ed14857901457a68e191063
deleted: sha256:e0c0bddff69b4e3a0491aeed6d823457a28eddeb987a8ac6c653488aa7d5f022
deleted: sha256:9ee8ee509261fe8a75bd76d959d13adfb3de5cb5684b0a49ea9b1398122c6a06
deleted: sha256:1d09fb0bc0d3cb6f9a295beac5f8f3d721fb75eaf57f2a3470c4996be3bb0516
deleted: sha256:12db4fba51f27c01e89da0c42968946114e18bfef4dcb4a993635595dda63f91
deleted: sha256:39ebbea9d877c4299e0e9ea1f01910c9a5ec260b739ff2ea0c49058295d069f1
deleted: sha256:368b65a1b9e1d65735fa003fcf838f280d4f3d68c64f0198278b4884721df089
deleted: sha256:e5b498606347ce574caba51cc3d07c97b76fddccc4c6fce3b9457ae184c092ce
deleted: sha256:207c294d2b285885c9f42f9bcb7a82fcc594e5cd929d6be630320ebc40d49c8b
untagged: nextcloud/aio-redis@sha256:0c40a1c04dc65a854cca6ed223af4077124cce4391889790f8cce81bdbee0695
deleted: sha256:7410a5ea39b355eb37bc3215c696c278e59bebb25db49c2a62245c14cd77acfe
deleted: sha256:8a6ca87e9cafa4a16eb33559ac6c89c87b7ba801109e241a0a9b14648da9d679
deleted: sha256:29381b468beca3a92f9c6eb8fe30bc2d74012a9c2a7ebd61fae0ee84301eeed8
untagged: nextcloud/aio-nextcloud@sha256:999ebf29ca1eb0936dee548f11050f1e074310588e93c159bd78073bd9151ca3
deleted: sha256:db8393795b6fb0f4abbb8e33569ec795b8ce5cf71d4058ba7471808876d85fb1
deleted: sha256:6b219e19419578588e14a75e2706e544a6ffc1959b6dee4eba033d9185093fc5
deleted: sha256:7b9a7082ce177cb092d8520d98797d0f410a8cfb7acf2809d9970022a96e1a60
deleted: sha256:0275159265e1b0cb3b95e36cd88eaf645b428166930a8ddf4e9862bd7cb63e08
deleted: sha256:5f23d2892c0ea2322590c113210a7455d0362177c9b23cc6309f5050cd522236
deleted: sha256:5aa1489646936b40a4bee79fd6319d6668661650a1de0e960295edb7fea958f9
untagged: nextcloud/aio-collabora@sha256:2cc5f044bc55a3ac317acca98e2e26db7934b5b2eec8cff9627607ce5c0d95a2
deleted: sha256:85eedcf9c95ecbb254a3d2934b8400327884780a42ff3182d2f3759711a8413e
deleted: sha256:588acfe4ac6fd901412ab8b9a4963004316b8a38003ca3215f70cdaaf6102189
untagged: nextcloud/aio-borgbackup@sha256:b86928e139dad4d5e19f308ad57c387e04fb76830482b5101f17ce98478fc950
deleted: sha256:1fa5a6c33763db04fdf5b3a88ccf78bd946d347ba7f7f6b6dcd9573022781dd1
deleted: sha256:bca3676fe6d6a2d953cb5abec180200873e7d41040debd0541773223c543bf9a
deleted: sha256:c36668fdefe27fe2c3151ddbc17ec5e952d0bf2b640ce39f226531f4a62153cb
untagged: nextcloud/aio-notify-push@sha256:268ca4ace9601ca2d4ee7e11f06bd6e68760ec3f2c17840a50619f7683efcb86
deleted: sha256:0866648c3dd351105db7f11cec2ce8ad24820b706f43489c07100e8fe9e03fae
deleted: sha256:687bd3dcde07ddc1e59a29deaab63aecca7cdbfe93ec1e1357f29f3da9b12bdf
deleted: sha256:e76cb908ee49069fbdd76ec4a24da7d170b908b62afb122fe888d764bc7a56b2
untagged: nextcloud/aio-talk@sha256:8cc09e203c3ab2714edb8e0f39d3cdc599a7f79456ecbb10dced85d2069e16f8
deleted: sha256:5c9a709d89730e64bdfdf817bc20a478df4ad86d2718242eafffe07dc9b3d567
deleted: sha256:1655d710251ad297f2cf868897f153c845e84a449068eb75cd66c4871377cc37
deleted: sha256:198043dbf936b7f9d692b6aff0c17cdcd0a44dd268faa6295626e73bac29eb7d
deleted: sha256:c48cca70206792a60b9aac0a848d84928c8ffd2a9dc7d90c23c5a067b6e692ab
deleted: sha256:995744c10a0e9f79805872fb7bce79c49c17d51e6fa614b465e843ffbf22c078
deleted: sha256:29105e8bd74001f02cf8bc43bc32585f0424253996afc71f694649150557a960
Total reclaimed space: 1.212GB
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
Deleting duplicate sessions
Total reclaimed space: 0B
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(56): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(476): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(181): Slim\App->run()
#13 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
Code: 404
Message: Not found.
Line: 76
#13 {main}
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
[10-Aug-2023 16:53:25] NOTICE: Terminating ...
[10-Aug-2023 16:53:25] NOTICE: exiting, bye-bye!
[Thu Aug 10 16:53:29.863552 2023] [mpm_event:notice] [pid 106:tid 139747837066056] AH00491: caught SIGTERM, shutting down
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
{"level":"info","ts":1691686426.343267,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Aug 10 16:53:46.495886 2023] [mpm_event:notice] [pid 96:tid 140210998901576] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.1 configured -- resuming normal operations
[Thu Aug 10 16:53:46.495934 2023] [core:notice] [pid 96:tid 140210998901576] AH00094: Command line: 'httpd -D FOREGROUND'
[10-Aug-2023 16:53:46] NOTICE: fpm is running, pid 100
[10-Aug-2023 16:53:46] NOTICE: ready to handle connections
[10-Aug-2023 16:54:07] NOTICE: Terminating ...
[10-Aug-2023 16:54:07] NOTICE: exiting, bye-bye!
[Thu Aug 10 16:54:09.707927 2023] [mpm_event:notice] [pid 96:tid 140210998901576] AH00491: caught SIGTERM, shutting down
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
[Thu Aug 10 16:54:45.343228 2023] [mpm_event:notice] [pid 96:tid 139938018933576] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.1 configured -- resuming normal operations
[Thu Aug 10 16:54:45.355665 2023] [core:notice] [pid 96:tid 139938018933576] AH00094: Command line: 'httpd -D FOREGROUND'
{"level":"info","ts":1691686485.5103939,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[10-Aug-2023 16:54:45] NOTICE: fpm is running, pid 100
[10-Aug-2023 16:54:45] NOTICE: ready to handle connections
[10-Aug-2023 17:17:04] NOTICE: Terminating ...
[10-Aug-2023 17:17:04] NOTICE: exiting, bye-bye!
[Thu Aug 10 17:17:06.983495 2023] [mpm_event:notice] [pid 96:tid 139938018933576] AH00491: caught SIGTERM, shutting down
+ BACKUP_TIME=04:00
+ DAILY_BACKUP=1
+ set +x
{"level":"info","ts":1691687861.0967069,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Thu Aug 10 17:17:41.206705 2023] [mpm_event:notice] [pid 97:tid 139852591147848] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.1 configured -- resuming normal operations
[Thu Aug 10 17:17:41.210546 2023] [core:notice] [pid 97:tid 139852591147848] AH00094: Command line: 'httpd -D FOREGROUND'
[10-Aug-2023 17:17:41] NOTICE: fpm is running, pid 103
[10-Aug-2023 17:17:41] NOTICE: ready to handle connections
Regards,
Can you try to connect via https://ip.address.of.the.server:8080 ?
Ok I just tried it and it works.
I feel silly for not even trying this first step on my own…
It intrigues me all the more because no modification has taken place on the host machine as well as at the level of the containers on my part.
Why does it no longer work from its URL? Any ideas for leads or investigations to be carried out? No config changes have been made on my side for some time.
Regards,
Hi @szaimen ,
I’m sorry but for me the problem is not solved yet, because I can’t really access the AIO interface like normally. After much research I found this topic which is very similar to mine. I applied what you recommend and after restarting the containers from the interface this time I can connect from the administration settings but it redirects me to https://public.ip.address.of.this.server: 8080/ and not https://domain.name.of.this.server:8080/.
I confess to not really understanding this change and how to fix it.
Thanks again for your help.
Regards,
Yes, this is intended.
This is not going to work because it uses a self-signed certificate which gets blocked once you open the Nextcloud domain due to HSTS.
You could open https://domain.name.of.this.server:8443 to work around the Problem.
Ok, I understand but this problem appeared overnight. Since the beginning of the implementation of my nextcloud infrastructure, it has always worked very well like this, having never modified the configuration of the reverse proxy (nginx proxy manager). Is this change due to a patch or a new update?
Because this malfunction means that I no longer receive notifications on my smartphone via the Nextcloud application telling me that the backups and updates have gone well.
As for opening port 8443 as a workaround, I’m thinking of trying. If I summarize correctly, there are no modifications to be made on the reverse proxy side, just to uncomment port 8443 in my docker-compose file and restart everything nicely. Will port 8443 be taken into account when redirecting to the AIO interface?
Thanks for your lights.
Regards,
Ah so you have a reverse proxy in place. Then it is more difficult. I would recommend to simply use https://ip.address.of.the.server:8080 or is this not possible?
It is quite possible, since I am the only person to access this interface. But I would like to understand why it no longer works as initially and also find the update notifications and backups at the same time which disappeared at the same time.
After some research I find these logs in the containe “notify-push”
[2023-08-12 08:39:37.434987 +00:00] WARN [notify_push::connection] src/connection.rs:75: Invalid credentials
[2023-08-12 08:39:37.564506 +00:00] WARN [notify_push::connection] src/connection.rs:75: Invalid credentials
Then please do.
It is complicated to explain but expected if you use https://domain.of.the.sever:8080 instead of https://ip.address.of.server:8080.
This is most likely unrelated and a different issue.
Ok, a big thank you @szaimen .
I will opt for this operation there as long as it works and it is not due to a configuration error on my part or an anomaly on my instance.
Regarding the lack of notification for backups and updates I suspected that I had to open another issue, I’ll get to it as soon as possible.
